1988 Grand Marquis Heater Problem
Old 12-18-2005, 08:24 PM
roaddogg's Avatar
Not getting any heat out of the heater but both inlet and outlet hoses to the heater are hot. Still can not get any heat through the vents. Get alittle warm air when in the defroast position. Themostat and water pump have been changed. Any ideas?
Thanks for your help.
Old 01-06-2006, 03:48 PM
conan312's Avatar
does the fan blow any air at all? or just cold air?
Old 01-07-2006, 05:34 PM
WWEB's Avatar
do you have manual a/c or elec contol?
Old 07-30-2006, 08:34 PM
1breaux's Avatar
Look for a hot water valve that may be stuck closed. It is located on the heater hose from intake. It may be stuck closed. I suggest replacing it. 8 to 10 dollars is a reasonable price.
Old 08-07-2006, 01:03 PM
kayakfish's Avatar
Hey I have a 1992 and had the same problem ended up replacing the heater modulater 800.00 later, you have to take the intire dash loose and replace the thing. Good luck[img]smileys/smiley5.gif[/img]
jordanc
11-30-2013 11:46 AM
gearheadmike
10-10-2011 06:50 PM
88marquis
10-19-2009 11:30 AM
COOPERATIVE
09-21-2009 12:02 PM
Ritzbury
07-08-2008 01:46 PM
Quick Reply: 1988 Grand Marquis Heater Problem
