1997 GM Ignition Failure
Old 05-15-2017, 11:54 AM
DiggerBlue's Avatar
Default 1997 GM Ignition Failure
I have an intermittent problem. On occasion, turning the key results in absolutely nothing except activation of door locks. I can wait some length of time, i.e., an hour, and try again and it will start with no problem. I believe this is a digital issue.
I'm looking for an economical resolution. Independents tend to be inadequate on digital support. A dealer would charge me much more than the car is worth, but could likely resolve the issue for a 4 digit sum.
Any insights on this?
Old 05-17-2017, 10:34 AM
Try this:
Get a shop rag or paper towel to hold below the Ignition Lock.
Insert the plastic tip of a can of WD-40 into the ignition keyhole -- spray into the lock for five (5) seconds.
Wipe up any stuff that comes out of the lock.
This may not work for you, but this simple trick has saved A LOT of "ignition problems" for me and my customers over the years.
Good Luck !!
dhoffer1
03-10-2010 12:01 PM
92Mercury
01-04-2008 03:12 PM
Brandon
11-18-2007 08:31 PM
abbado
08-17-2007 08:25 AM
BSVJ
12-15-2006 01:58 AM
Quick Reply: 1997 GM Ignition Failure
