Hesitation when I first carnk car
Old 02-14-2005, 03:14 PM
tigerfan31's Avatar
1996 Grand Marquis.
I am taking her in on Thursday and wanted to check out what you think.
I've noticed that when I crank the engine she idles rough and then down, sometimes shutting down. I also could smell gas like she is flooded or something when around front end. Once I have her in drive though she seems to ride fine. No jumping or idling problems.
I'm thinking fuel filter, fuel pump or just tune-up!
Any tips so as not to get ripped off would be appreciated.
Thank You,
Old 04-18-2006, 06:16 PM
libertylm's Avatar
Did you pull the plugs? You should be able to tell if the vehicle is flooding by the plugs. If they are sooted black, then yes, it is probably flooded. It probably couldn't hurt to replace the fuel filter either.
Old 04-19-2006, 12:33 AM
WWEB's Avatar
SOUNDS LIKE POSSIBLE IAC PROBLEM BUT NEED MORE INFO ON START UP CONDTION DOES IT START BACK UP DOES IT HESITATE WHEN TAKING OFF?DOES THE RUN ROUGH GO AWAY HOPE I CAN HELP LET ME kNOW
Old 04-19-2006, 09:33 AM
tigerfan31's Avatar
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Sorry, I had her fixed when the problem arose, I think she needed injectors cleaned or something like that, she purrs like a kitty nowThanks for the info.
crazycars
02-15-2008 12:00 PM
Linky
06-27-2006 11:33 PM
ima72
04-09-2006 11:33 AM
Melissa B.
10-03-2005 10:19 PM
tigerfan31
03-28-2005 06:18 PM
Quick Reply: Hesitation when I first carnk car
