How to turn off seatbelt alarm - Mercury Forum - Mercury Enthusiasts Forums
Thread Tools Search this Thread
Old 12-08-2008, 09:26 PM
I don''t have the manual for my car. I was wondering if anyone knows how to disable the seat belt alarm in a 2002 Grand Marquis (besides buckling the seat belt[img]smileys/smiley2.gif[/img]).
Old 12-09-2008, 07:25 AM
you''d have to figure out how the seat belt buckle worked and modify that circuit to make the car think it''s always buckled. there is no way to disable it to my knowledge. it''s a safety feature to get people to buckle up even for the short trips down the street because the possibility of getting in an accident near the home is greater than at great distances due to the simple fact that people are generally closer to home most of the time.
personally I can''t get into a car and not buckle up... it doesn''t feel right.
Old 12-09-2008, 03:37 PM
I agree I don''t feel comfortable driving without a seat belt either. Its just annoying when I''m parked with the car running and the damn seat belt chime keeps going. Would modifying the circuit be as easy as just bypassing the seat belt and linking the circuit or is there some other way?
Old 12-09-2008, 05:43 PM
I would think that would do the trick, but I don''t have a similar vehicle to check. My 88 doesn''t have a seat belt buckle sensor and I don''t think my wife''s 93 vic does either. I know neither one of them have the complaining alarm that yours does. I do think they''re supposed to not trigger if in park, but I could be wrong since I don''t have one myself and I''m guessing.
Old 12-10-2008, 03:09 PM
it''s so easy
Old 12-10-2008, 05:29 PM
Mer.Gra.Mar: </span>
how did you go about doing it?
Old 12-10-2008, 08:03 PM
It''s a series of buckling and unbuckling of the seatbelt. I''m going to get my manual because I don''t remember the order of things. BRB
Old 12-11-2008, 04:07 AM
thanks I would really appreciate that.
  #9
Old 12-11-2008, 04:11 AM
I found the answer. Here it is:
One time disable
Any time the safety belt is buckled and then unbuckled during an
ignition ON cycle, BeltMinder will be disabled for that ignition cycle only.
Deactivating/activating the BeltMinder feature
Read steps 1 - 9 thoroughly before proceeding with the
deactivation/activation programming procedure.
The BeltMinder feature can be deactivated/activated by performing the
following procedure:
Before following the procedure, make sure that:
* the parking brake is set
* the gearshift is in P (Park) (automatic transmission) or the neutral
position (manual transmission).
* the ignition switch is in the OFF position
* all vehicle doors are closed
* the driver’s safety belt is unbuckled
* the parklamps/headlamps are in OFF position (If vehicle is equipped
with Autolamps, the Autolamps feature MUST be turned off.)
To reduce the risk of injury, do not deactivate/activate the Belt
Minder feature while driving the vehicle.
1. Turn the ignition switch to the RUN (or ON) position. (DO NOT
START THE ENGINE)
2. Wait until the safety belt warning light turns off. (Approximately 1–2
minutes)
* Steps 3–5 must be completed within 60 seconds or the procedure will
have to be repeated.
3. Buckle then unbuckle the safety belt three times, ending with the
safety belt unbuckled. This can be done before or during BeltMinder
warning activation.
4. Turn on the parklamps/headlamps, turn off the parklamps/headlamps.
5. Buckle then unbuckle the safety belt three times, ending with the
* After step 5 the safety belt warning light will be turned on for three
seconds.
6. Within seven seconds of the safety belt warning light turning off,
buckle then unbuckle the safety belt
* This will disable BeltMinder if it is currently enabled, or enable
BeltMinder if it is currently disabled.
7. Confirmation of disabling BeltMinder is provided by flashing the safety
belt warning light four times per second for three seconds.
8. Confirmation of enabling BeltMinder is provided by flashing the safety
belt warning light four times per second for three seconds, followed by
three seconds with the safety belt warning light off, then followed by
flashing the safety belt warning light four times per second for three
seconds again.
9. After receiving confirmation, the deactivation/activation procedure is
complete.
  #10
Old 12-11-2008, 05:08 AM
Tripper511 :
<DIV id=result_box dir=rtl style="TEXT-ALIGN: left" align=left>If the seat belt alarm canceled from yourcar , this would be automatically cancel the air bag</DIV>
Thread Thread Starter Forum Replies Last Post
Alarm goes off randomly... perrotto Sable 2 11-20-2012 04:45 AM
Turn Signals Won't Shut Off After Making a Turn Hetron Grand Marquis 0 03-06-2012 10:36 PM
Alarm keeps going off randomly. PLEASE HELP! 2001SableLS Sable 1 09-06-2010 12:40 AM
How to turn off the Seat Belt reminder alarm davidmolathe Milan 5 03-16-2010 10:23 AM
2000 sable alarm is pissing me off 11teen Sable 1 05-31-2009 03:29 AM
Tags
08, 2002, 2004, 2006, alarm, belt, buzzer, chim, disable, grand, mariner, marquis, mercury, seat, seatbelt, turn
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
