Air conditioner starts from defrost then switches to dash vents
Old 06-13-2012, 11:24 AM
rbl_at_home's Avatar
Post Air conditioner starts from defrost then switches to dash vents
My Mercury 2004 GS with ETC Air conditioning starts from defrost then switches to dash vents.
Is the a way to reset the ETC to factory defaults?
Thanks in Advance
Russ
Old 06-13-2012, 03:49 PM
91GrandMarquisGT's Avatar
Usually when a HVAC system goes to defrost there is a lack of vacuum to operate the right mode. Defrost is the default when the vacuum source is gone. The blend doors, and mode doors are operated by engine vacuum. Start with checking the feed from the engine to the HVAC box. Then pull the Climate control head and ck for vacuum there. The head could also be bad. Not sending the vacuum to the right place quick enough.
Old 06-15-2012, 02:44 PM
I do not believe it is the Vacuum. All of the other settings, except vent work OK
Old 06-27-2012, 01:10 PM
AZFastDan's Avatar
Default Default
For safety reasons the default position is defrost on. If/when the system operates correctly it changes to a/c. If it stays on defrost, then you have an issue.
Old 07-25-2012, 02:23 AM
TrentMassey's Avatar
Old 08-23-2012, 03:13 AM
KelleyHoward's Avatar
Criminal Minds Season 7 DVD
Once Upon a Time Season 1 DVD
jimco23
05-29-2011 08:59 AM
sarahb_smc
11-02-2010 03:10 AM
caveman
01-14-2009 03:23 PM
eubank
07-24-2007 10:27 AM
MN250R1
07-16-2005 11:45 PM
Quick Reply: Air conditioner starts from defrost then switches to dash vents
