Milan Discuss the newest sedan to the line up, the Mercury Milan...
2006 MilanV6 Premier Code P0506 Surging..Throttle Body issue maybe?
Old 03-03-2016, 11:11 AM
Firedawg50's Avatar
Default 2006 MilanV6 Premier Code P0506 Surging..Throttle Body issue maybe?
Hi
I have an 06 Milan Premier that likes to surge when you are at a stop light, in reverse or in any gear with the brake applied. I have read a ton on this and it all points to a dirty throttle body. I took it off, cleaned it how the directions read with the appropriate cleaner, and assembled it again. Still happening. I did notice when I had it out, that the butterfly valve doesnt close all the way on its own. I can push it closed and hear the motr cycle, but if I let go of it it opens a little. Could this be causing it, if not, what else could I look at. It did throw a code P0506 for Idle Air control. Any Guidance is much appreciated.
ROBBINFOOLS
08-29-2017 02:10 PM
dakotapoe18
04-06-2011 01:27 AM
RogerB34
06-01-2008 10:12 PM
TKemp Felony
03-13-2008 09:47 PM
Quick Reply: 2006 MilanV6 Premier Code P0506 Surging..Throttle Body issue maybe?
