keypade code
Old 11-23-2013, 05:48 PM
Terrence's Avatar
Default keypade code
Need some assistance in locating the factory code for a 2007 mercury mountaineer that was recently purchased!!! remote works fine, but can't use the keyless entry pad on the door and would really love to!!!
Old 08-25-2014, 12:57 PM
Scott Clancy's Avatar
Open your rear passenger door and fold back seat forward. You will see where your seat-belt connects to the frame. Gently pull the housing around seat-belt near frame off. After doing this gently pull the bottom piece of plastic back revealing a module. On this module will be 5 numbers in large print. that should be your factory keypad code for your drivers door keypad. If entered correctly you will hear the driver door unlock. By pressing 3/4 key it will open all doors and by pressing 5/6 button should unlock the lift gate Glass section. ** Note to unlock all doors and or rear lift gate glass the proper buttons should be pressed within 5 seconds of entering main code.** Hope this helps
