Sable will not turnover
Old 03-19-2011, 10:45 AM
jakins's Avatar
Default Sable will not turnover
My daughters 2001 sable will not turnover even while jumping it. Maybe the starter or solenoid?? Any help will be appreciated.
Old 03-19-2011, 07:57 PM
perrotto's Avatar
Does it crank or just click? If it just clicks it's probably the starter or really dead battery. If it tries to start or cranks then it's probably fuel delivery. Just something to think about...
Old 03-20-2011, 01:22 AM
Bulldozer's Avatar
At 10 years of age both are a possibility. It could also be corroded connections or battery cables. Best way to isolate is to do voltage checks at each connection & also voltage drop test at each connection. You should be able to hear the solenoid click. If not check to see it is getting power to it from the key.
If no power to it, then ignition switch or neutral switch. Speaking of neutral switch, is the transmission in park or neutral?
vtraudt
05-27-2012 09:03 AM
Cathy Kirkes
04-14-2007 11:34 PM
mishalah
11-07-2006 07:50 AM
mishalah
10-21-2006 12:31 AM
stephanie80
02-08-2006 02:04 PM
Quick Reply: Sable will not turnover
