How to turn off seatbelt alarm
Old Dec 11, 2008 | 07:53 PM
  #11
Cyberats's Avatar
Related problem, safety belt alarm on at any time driver door is open, even with no keys in ignition or any lights on. This problem developed after changing the turn signal switch at the mechanic. Not going back to the dumbass (who knows what else he finds wrong, this was his second and final mistake), any suggestions ? Did he steal my airbag ?
1990/91 Mercury Grand Marquis LS.
Old Dec 11, 2008 | 08:58 PM
  #12
sounds like he may not have connected everything back up correctly in the steering column when he put it back together. That, or a relay has stuck on. stolen airbag wouldn''t do anything like that. at worst, nothing would be noticeable with a stolen airbag. at best, the airbag light would be on all the time. There may also be something laying loose inside the steering column that may be shorting something. might just take the shroud off (top and bottom covers) and see if there''s something obvious.
Old Dec 16, 2008 | 12:05 PM
  #13
Cyberats's Avatar
Ok, thanks, I think I can do that.[img]smileys/smiley16.gif[/img]
Old Mar 14, 2009 | 04:21 PM
  #14
Tripper511's Avatar
Originally Posted by Mer.Gra.Mar
Tripper511 :
<DIV id=result_box dir=rtl style="TEXT-ALIGN: left" align=left>If the seat belt alarm canceled from yourcar , this would be automatically cancel the air bag</DIV>
FYI, I checked on that and disarming the seatbelt warning DOES NOT deactivate the air bags. You need to remove fuses in order to deactivate them seeing how Ford does not want to make it easy for the bag to be turned off.
Old Jun 15, 2021 | 02:50 PM
  #15
KRocky417's Avatar
Default How to get the seat belt chime/ warning bell to stop going off.
First go under your seat. Second look at the bottom of you seat belt lock for some wiring coming out of it. Three follow the wire until you find where it is plugged in at. and four unplug the wire. this should stop the chime from going off.
perrotto
Nov 20, 2012 03:45 AM
Hetron
Mar 6, 2012 09:36 PM
2001SableLS
Sep 5, 2010 11:40 PM
davidmolathe
Mar 16, 2010 09:23 AM
11teen
May 31, 2009 02:29 AM
