Serpentine Drive belt squeaks
Old 06-25-2013, 04:38 PM
mrrotary's Avatar
Talking Serpentine Drive belt squeaks
I have seen this listed on several forums - I have a 1994 Sable with 194,000 miles and recently had a serpentine belt squeak which I dived into because I could not get it to stop. Ford Dealer said it was my water pump. HOWEVER I went simple first - thank god for "lifetime" repair parts from AutoZone! I changed the guild pulley, the belt, then the belt tensioner, water pump, power steering and finally the alternator and NOTHING WORKED stilled had a high pitched squeak. (Note I did find a small water leak and while you are near water pump ALWAYS change out the 4" of hose buried behind all of these parts.)
I went back and changed the tensioner again and DISCOVERED the bolt provided was a bit loose without the tensioner. SOLUTION - I put some RTB on the bolt and tightened to specs and corrected the whole problem. Hope this helps many of you save all the above work.
searchlight4759
08-03-2012 11:27 PM
trailhand
05-19-2010 01:08 AM
bkatzman
11-21-2009 04:32 AM
misteral
05-02-2009 05:21 PM
rickmichaels
04-19-2006 12:04 AM
Quick Reply: Serpentine Drive belt squeaks
