No heat, yet again, no answers here so far
Old 10-19-2013, 02:43 PM
markury's Avatar
Default No heat, yet again, no answers here so far
Hi all,
My 98 sable had no heat. I brought it back to the mechanic i bought it from. He did a full coolant flush, and flushed the heater core! Heat was so hot, I could barely keep it on...THEN!
The next day, my upper radiator hose sprung a leak and my coolant ran out slow at first, then faster.
I replaced the upper radiator hose, and now, no heat again! $240 to be back at square one.
Any idea why after I replaced the hose, the heat died? Bubble in the system? Tried to run it with cap off reservoir, and tried to bleed out the air by squeezing the upper radiator hose. All hoses get hot. possible air blockage? if so, how do i get ti out. Makes no sense why the heat quit afterwards, and my mechanic decided not to return my calls....any help would be appreciated, its starting to get cold out and im absolutely broke!!
Old 03-14-2014, 05:29 AM
Dracon Doctorow's Avatar
if mechanic is not returning your calls find a new one. That being said not sure what year your sable is like 95 to 99 I have a 97 the heating system in these cars are the worst I have ever seen. once you think you have it something else goes wrong. finally had mine fixed. it was the dreaded water pump course with the nasty rust that happens in these had to replace the heater core as well. But if it was working one day then nothing might want to check your Actuator there is a little white box under the dash that opens and closes your Blend door that allows the heat to come though. that might have gone bad only allowing cold air to come though. if you look under the dash there will be a cover that covers this box but if you can see past it or get it off when you turn your heater from cold to hot then back again this should be moving your heater doors open and closed. sorry for the long winded reply.
Old 07-28-2014, 08:37 PM
Daniel Hebert's Avatar
My '02 Sable heater died Dec' 13. My mechanic did the flush thing and several other attempts that cost over $300 and it was a waste of time and $. Took it to a dealer garage and they had the diagnostic equipment, etc. and they got the heat back to 95% . Sables need attention at the 100K miles point, plugs, injectors, heating, transaxle service, etc.
greggyc
12-30-2008 06:00 AM
88Tracer
02-07-2008 07:15 AM
11-22-2007 10:01 AM
Melissa B.
03-13-2006 09:18 PM
Windzer
04-29-2005 09:18 PM
Quick Reply: No heat, yet again, no answers here so far
