Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification... let's hear about it here...
fire wall
Old Apr 30, 2007 | 08:37 AM
osmossis's Avatar
i have a 93 merc gm i recently purchaced it now i am put 6x8'' fosgate componets in the front with alpine 6x9" in the back i got 2 fosgate twelves n the back with a 1500 watt fosgate mono block. the front compoets run on a 360 watt amp jensen, n the rears a 600 watt alpine. now the only problem is i can't get the damn power cable through the firewall every thing else is wired!!!!! i have tried everything but drill the the damn firewall myself any one ever do a GM or have any ideas would be greatly appreciated. Edited by: osmossis
Old Jan 17, 2008 | 06:58 PM
easiest way i have found to run a power line from the battery through the firewall is to find an existing hole with grommet in firewall. i found a plug in the firewall of my car that has the antenna going thru it. i took a knife and notched it on 2 sides so that it would push thru. i use a straightened coathanger with a small hook formed on one end to old the wires. after grabbing the power line with that use electric tape and use that set up to pull it thru. i do the same thing when i run speakers in my doors and to get in places where i have more trouble to access.
jhfshfk
Dec 12, 2012 12:31 AM
jhfshfk
Nov 27, 2012 08:25 PM
jhfshfk
Nov 27, 2012 08:24 PM
larry stone
Oct 8, 2008 02:34 AM
4cbuck
Feb 22, 2007 09:21 PM
