Tracer Discuss the Mercury Tracer here...
Fuses
Old Mar 21, 2005 | 03:16 PM
lissasue3's Avatar
I am having a problem replacing the fuse connected to the center console. I cant seem to get the old one out. I dont want to pull too hard and break something. Is there some special way to remove it? Is there a reason why it might not be coming out?
Any help would be appreciated!
Old Mar 21, 2005 | 06:03 PM
If you have a small blade screw driver apply light pushing pressure outward on the side of the fuse and should come loose.
Old Mar 21, 2005 | 09:59 PM
lissasue3's Avatar
thanks i will try that!
Old May 9, 2005 | 01:40 AM
dfreise's Avatar
The early tracers have a fuse puller located on the back of the fuse box cover. Or you can get one at the local parts store for a buck or two. The puller just slips over the top of the fuse, you pinch the puller and pull and presto the fuse is out.
greenline
Jun 20, 2011 04:47 PM
jcopen2
May 22, 2008 09:33 PM
phatphipps
Oct 2, 2006 10:11 PM
gerryrainville
Apr 24, 2006 03:33 PM
shawn
May 13, 2005 03:00 PM
