1996 Sable wiper problem
Old Mar 27, 2005 | 02:34 AM
Holman's Avatar
Hello everyone. I hope someone can help me. My wipers are finicky. Sometimes they work and sometimes they don't. I had the wiper/signal arm box on the column changed under warranty and it worked for awhile. I changed the fuse and it worked for awhile. I changed the wiper signal box on the column again and it worked for awhile. Does anyone know what to do next? Also the passanger rear doorlock makes a buzzing noise and doesn't work. Any suggestions to that too? This is much appreciated.
Thanks Mike
Old Mar 27, 2005 | 07:47 AM
wow i had a problem like that i took it apart
and solderd a wire back on that had broke
it was not easy but it works fine . the lock
sounds like its seized.
Old Mar 27, 2005 | 11:51 AM
Holman's Avatar
Thanks Windzer for the reply. Where was the wire that you soldered? I think you could be right. With the door lock, when it warms up a bit I'll pop the panel off and take a look. Any ideas on how to pop the door skin off?
Thanks Mike
Old Mar 27, 2005 | 05:55 PM
its a pain but there was three screws on my
back door my back door window moter was seized i took it apart and broke it free and lubed it up.Turnsignal the wire is actuly going down the inside of the turn signal handle it broke free from the conecter inside the unit . witch out for springs and sutch when you take the scews out . if you have any problems puting it back together let me know you need about three hands to get it right I build little models N scale like the trains that are about the size of a AA battrey layng flate so it was a little tricky but i got it.
you,ll see what im talking about if you take this on .Advance Auto Parts sels this for 43.97
for a 94 but if you'r cheap like me you'll do it your self lol.
EddieE
Mar 7, 2013 07:09 PM
JSanchez830
Jun 28, 2012 06:31 PM
simon_scott7
Sep 18, 2008 10:45 AM
MHobbs87
Mar 15, 2008 06:29 PM
54Strife
Jul 17, 2006 03:57 PM
