A/C Electrical problem 95 Sable
Old May 2, 2005 | 12:12 AM
pinkerton's Avatar
Fuse number 17 has blown which is the fuse for a blue/red wire that goes to the A/C, vent, defrost selecter switch. Then I believe it goes to the condenser switch. The blue/red wire also branches of at the selecter switch and goes to a heater door, or something like that.
When I put a fuse in it doesn't alway blow right away. I can cycle between heat and A/C but it will eventually blow the fuse. Sometimes it does it right away. I have unplugged they condenser switch and it still does it.
Hoping someone has some advise. I don't really understand what the system is doing.
Thanks,
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old May 6, 2005 | 09:38 PM
gremlens in your switch replace it
Bruin1
Sep 25, 2007 09:53 AM
RIGBOSS
Jul 25, 2007 09:50 AM
lkmfcars
May 24, 2007 09:20 AM
beerwolf
Jan 21, 2007 12:11 PM
planalp
Dec 21, 2005 12:36 AM
