97 sable brake headache
Old May 3, 2005 | 12:49 AM
Bill's Avatar
I've had repeated problems with warping rotors and
my mechanics are at a loss how to proceed. any
similar situations out there?
Old May 3, 2005 | 01:47 AM
try a good set of quailty ford motor company original equipment pads and rotors. We have noticed on the older sables that the aftermarket equipment tend to not disapate heat quick enough and cause rotor warpage.
Old May 3, 2005 | 04:32 PM
Had a Caddy that had that problem, the engine idle too high and the guy had to ride the brake more. Had another car that the brake lines (hoses to caliper) bad, causing pressure to remain and cause a drag.
Old May 5, 2005 | 09:59 AM
Bill's Avatar
Thanks for the recommendation. Do you work for a Ford garage? Is this something you've seen often?
Old May 17, 2005 | 04:35 PM
A set of brembo rotors and wagner pads do a better job than the fomoco ones do,sorry.
Mikejustis6
Apr 12, 2015 08:08 AM
Mercuryowner1
Oct 2, 2013 08:50 PM
cobrahd1999
Nov 28, 2012 04:54 PM
stangcbr
May 15, 2010 10:37 PM
