Capri Discuss the Mercury Capri here...
Quitting at 3000 RPM
Old Jul 4, 2008 | 03:56 AM
PeterL's Avatar
94 SE Capri, 1.6L non-turbo Manual
Engine will not run above 3000 RPM. Great below 3000. Starts easy. Idle is smooth. Accelerates well, then at 3000 RPM it''s like the ignition is turned off. When revs drop off to about 2700 RPM the engine starts again, runs up to 3000 then quits again.
I''ve checked the Engine Management system and there are no error codes.
I would appreciate any advice on how to fix this problem.
Old Jul 27, 2008 | 01:44 PM
jason sereiko's Avatar
Could be a head gasket leak. Check the oil if there is any water in it. it would look white milky. A blown head gasket somtimes causes this because the motor is choking when high rpm''s are applied
Old Jul 27, 2008 | 04:32 PM
PeterL's Avatar
Just got the car back from the Ford man.
THe problem was a throttle position sensor. Didn''t show any error codes but replacement fixed the problem
Old Aug 16, 2008 | 11:07 PM
AWESOME!!! It is weird that did not come on the error code. anyway, great job on fixxing that car
Old Aug 16, 2008 | 11:15 PM
PeterL's Avatar
After three weeks of workingn just fine, it died again last night. Exactly the same as before. [img]smileys/smiley19.gif[/img]
So back to square one. The chariot is not working. It runs out of horses. Good thing my trust is still solid. Better yet that He is trustworthy!!
Old Aug 16, 2008 | 11:26 PM
rock on brother!. he is trustworthy and will never fail you.
most likely you have a faulty sensor and or connector. look at the pigtail connection and clean it out. was this an aftermarket part that was put on?
on these turbo cars the TPS pigtail gets hot and burns out the sensor and or the connector. check the connector
Old Aug 17, 2008 | 12:19 AM
PeterL's Avatar
Wish He would get here and fix my car (which is really His anyway) [img]smileys/smiley17.gif[/img]
The TPS was a brand new Ford original. ( I live in Oz, where the Capri was designed and built. It is badged as a Ford down here)
Checked the connector and the adacent wiring and it''s all good (Down here the SE was available in turbo and non-turbo models. Mine is non turbo)
So I am about to embark on a unit by unit check of all the sensors.
Old Aug 17, 2008 | 05:10 PM
please just come already!
There is a guy on this forum that hates you know who. if he starts to bother you like he is me because i have scriptue quote, just ignore him with kindness like I am trying to do. Don''t let him get to you. he will see the light someday.
Old Aug 17, 2008 | 06:40 PM
PeterL's Avatar
Thanks for the heads up.
jruppert
Jan 20, 2007 01:35 PM
ptrama
Jul 1, 2006 11:58 PM
imagethree16
Jun 27, 2006 11:51 PM
Motley
Jun 10, 2006 08:57 AM
schluppy
Nov 9, 2005 03:00 PM
