I own two Villagers.
Old Oct 15, 2004 | 02:11 PM
Douglas's Avatar
Hi ya all, I'm new here also and I'm glad I found this site so I can
learn more about my villagers and to meet new friends, thanks.
Old Oct 15, 2004 | 02:17 PM
Douglas's Avatar
I have a 96 villager with a fried knock sensor and I looked on the
block everywhere, and on top near the injectors but still no find.
Anyone know where this buggert is located, thanks[img]smileys/smiley4.gif[/img]
Old Oct 15, 2004 | 10:26 PM
Unless that knock sensor is causing you problems do not replace it... It is located under the intake manifold. I work at a linc merc dealer and we have replaced a few of those its a labor entensive job and not really needed unless you have a problem.... And Welcome to the forum
Old Oct 15, 2004 | 11:06 PM
Douglas's Avatar
Thank you MercAdvisor, I hooked a puter up to it because the engine
light kept coming on. when I erased the code it came on again after I
started the engine. It said the sensor was maufuctioning so I guess
I'll have to pick a weekend and see what I can do. $169.00 for a knock
sensor WOW!!!!!!!!! that costs alot, thanks again.
Old Oct 15, 2004 | 11:08 PM
check and see if you can buy that sensor froma nissan dealer if you can get them to sell it to you it will proably be cheaper.... same engine and trans
Old Oct 16, 2004 | 10:44 AM
Douglas's Avatar
I wish I had a nissan dealer near my place but I don't, but a Mercury
dealer is about 20 minutes away. I checked eBay but found them for
saabs. Today I have to replace two motor mounts on the lower frame
front and back, motor kicks up.....have a good day[img]smileys/smiley1.gif[/img]
Old Oct 21, 2004 | 12:15 PM
Douglas's Avatar
MercAdvisor?.....My wife has a "95" also and when she hits the key it
has a knocking sound in the warming up stage, and when it warms up it
goes away. Could this be a lifter going bad, or does it need to be
tighten? thanks for all the help on this site.
Old Oct 21, 2004 | 01:23 PM
Unfortunatly [img]smileys/smiley7.gif[/img]there were some years where as the engines got older the lower end would begin making some noise let me check into this a little more and i will find out as much as i can for you...
Old Oct 21, 2004 | 03:57 PM
Originally Posted by Douglas
MercAdvisor?.....My wife has a "95" also and when she hits the key it has a knocking sound in the warming up stage, and when it warms up it goes away. Could this be a lifter going bad, or does it need to be tighten? thanks for all the help on this site.
Sounds like oil starvation in top of head(under valve cover),might just be gunked oil passages. My 95 E-350(460 motor) did the same thing until I cleaned the top of the heads.
Old Oct 21, 2004 | 04:02 PM
Douglas's Avatar
WOW! if thats all, then I'll get a gaskit and see what I can do, you been a blessing in many ways! Thanks again.
