Idle in cold wx
Old Jan 24, 2009 | 06:41 PM
rickrylee's Avatar
Afterstarting in cold environments car dies. Must hold the excelerater to keep it running. What is the problem? Can not rely on the Korean ford place they just rip you off, if you are a foreigner.
Old Jan 25, 2009 | 01:15 PM
seems this is caused by the idle air control or mass air flow sensors. they probably need to be cleaned. if you do that, make sure not to touch the wires on the MAF sensor.
it could also be a bad coolant temp sensor. but from what I''ve been reading around the net, the first two are the best bet.
grtrnd1
Feb 8, 2011 11:34 PM
sumfunyet
Jan 5, 2009 07:15 PM
steve
Feb 14, 2006 03:20 PM
DavidT
Feb 9, 2006 11:20 PM
Brian E
Jan 20, 2006 05:01 PM
