ABS Light on - Error code C1145 - TSB
Error code C1145 (ABS light on) is rather common, Ford has several TSB's out there for that.
Someone just told me that he spend hundreds of dollars in changing parts in order to get it fixed, and the light still comes on.
Here is the likely cause (don't have the complete TSB's yet, will follow up):
ISSUE:
The Anti-Lock Brake System (ABS) Malfunction Indicator Lamp (MIL) may illuminate on some vehicles. Diagnostic Trouble Codes (DTCs) C1145, C1148, C1155, C1158, C1233, and C1234 may be stored in memory. This may be caused by a short due to water intrusion in the right or left front ABS wheel sensor harness connection(s).
Greetings!
ISSUE:
Greetings!
got the problem too. i´ve got a marauder from 2003! i changed the front right sensor, checked and clean every connector, changed the ABS module, and follow the pinpoint test from the ford workshop manual! what can be the reason, please help!
