2000 villager check engine
Old Sep 6, 2005 | 05:45 PM
pllewellyn's Avatar
The check engine light on my2000 VillagerEstate (100K mile no-tune) is illuminated. Before taking the car into the shop, any suggestions on things I can check myself? I've checked the obvious, such as fluids. The light is not intermittent, and the engine, which has~65K miles,runs relatively well. Edited by: pllewellyn
Old Jan 19, 2006 | 12:54 PM
Barquentine's Avatar
Get the code from the ECU, that's the way to find out.
It is probably going to be an oxygen sensor.
Old Feb 21, 2006 | 11:01 AM
scheuer1's Avatar
Most Advanced Auto Parts stores will run a Diagnostic check on your vehicle at no charge. You definitley need the ECU code to detect what is sending a signal to the check engine light. I had this problem with my 1999 Villager a number of times; first was the oxygen sensor then the MAPP sensor and finally the Knock Sensor. The dealership wanted $700.00 to replace the Knock sensor stating that they had to pull the engine to get at the back of the engine. I ended up trading it in for a 2005 Mariner. Good Luck!
214shaft
Jan 3, 2011 11:21 PM
damercga
Dec 31, 2006 05:24 PM
joshmerc
Mar 23, 2006 03:21 AM
hdfoor
Apr 29, 2005 10:57 PM
Chris
Apr 24, 2005 01:39 PM
