Rear Differential?
Old Oct 5, 2005 | 06:58 PM
872doorboat's Avatar
I know this might be a stupid question, but does my 87 Mercury Grand Marquis LS have a limited - slip differential standard? Also, what is the gear ratio if it does?
Old Oct 28, 2005 | 11:25 PM
satin aluminum's Avatar
doorboat;
Look up crownvic.net. There are many more members on that forum. They cover the Town car, the Grand Marquis and the Crown Victoria automobiles. They may be able to answer any question you may have. [img]smileys/smiley2.gif[/img]
Old Nov 1, 2005 | 04:56 PM
Patrick's Avatar
if you call any ford dealership, with the VIN, they can tell you every option that the car came with.
Old Oct 9, 2006 | 01:02 AM
cpettymore7777's Avatar
or jack up the back end. and spin one wheel. if the other wheel spins in the oppsite direction you do not have ls. (i believe that is correct)
Old Jun 25, 2017 | 02:59 PM
No Mercury Grand Marquis has a limited-slip differential as STANDARD equipment. The limited-slip diff is a factory OPTION.
The STANDARD equipment is an OPEN differential with a 2.73 : 1 gear ratio.
With the 4-speed Automatic transmission, the 2.73 gear will give you 80 mph at 2000 rpm.
speedyred
Sep 5, 2011 12:33 PM
aprilbecerril
Jan 27, 2011 10:42 AM
mof4000
Jul 2, 2008 11:39 PM
ahbaqi
Sep 12, 2007 05:10 PM
johnneypratt
Sep 6, 2005 08:44 PM
