idle air control vavle
Old 08-02-2009, 01:46 PM
mstorrs's Avatar
Default idle air control vavle
I have a 2004 mercury mountaineer and trying to see if theirs a iac vavle i need to replace. The book says that for this model i do not need to replace it. My check engine light is on and it pulls code 506 which is the iac. Any suggestions on should i replace it and also where is it located. Thanks for your help.
Old 08-02-2009, 10:19 PM
try cleaning it and the throttle body. It may just be clogged.
Old 08-03-2009, 09:06 PM
mstorrs's Avatar
I'm trying to locate where the idle air control valve or motor is on my 2004v6 mercury mountaineer. I'm not a mechanic so you have to give me detail by detail on where i can find it. Thanks.
Old 08-03-2009, 10:29 PM
it should be on the throttle body (the part that the air filter intake mounts to that the cable from the accelerator is connected to with the big flapper inside that allows more air into the engine when you "hit the gas"). There should be a hole before and after the flapper that the IAC connects to and controls airflow through. Happy hunting.
Old 08-04-2009, 04:39 PM
mstorrs's Avatar
Default iac
I think i may have found the problem with my iac on my 2004 mercury mountaineer. I took the cover off from the air filter and throttle and sprayed throttle and air intake cleaner in the hole where the big flap(that opens and close)at. It seems to be running fine but i was wondering if i need to take any parts off to farther clean it more.
Old 08-04-2009, 05:50 PM
I didn't on my MGM. I just kept spraying, starting, clearing, spraying until the black gunk was gone. Be sure not to spray too much before starting the engine and clearing it out or you may detonate something unpleasant.
Old 08-19-2009, 06:39 AM
mounty2004's Avatar
Default Location of IAC?
Can anyone help me to locate the IAC for my mountaineer 04 v6? Please see attched picture. Because I need to clean it also. Thanks.
Old 08-19-2009, 10:00 AM
I don't see it in that picture (it could be on the back side of the throttle body).
check the image out over at rock auto
http://www.rockauto.com/catalog/rafr...1428230k382741
and see if you can find something that looks the same as that. it should be connected to the same part as the throttle and cruise control cables.
Old 08-20-2009, 01:03 AM
Looks like that is it right to the rear of the oil filler. 4 screws holding down the the metal plate cover, no?
kryichek
03-22-2023 10:21 AM
jferline
11-19-2009 07:40 AM
jferline
09-27-2009 07:10 PM
kdk71mgb
09-02-2009 08:07 AM
014EVER
08-25-2009 08:25 PM
Quick Reply: idle air control vavle
