Tracer Discuss the Mercury Tracer here...
Hard starts Spit and Spudder
Old Feb 5, 2006 | 10:35 PM
brickman's Avatar
I have a 99 tracer.
Hard Starts in the Cold mornings. If I try to excel at Low RPM it will sputter. It started happening about a month and a half ago andit has gottenworse over the last week. I am leaning towards Timing belt replacement and or Cleaning, replacing most parts that I can. I am guessing, somehow, the Timing jumped. I was hoping it hada chain because those have guides that go out.
I don't understand how the Timing belts or Timing Jumps perse,can anyone explain?
Would this be a good place to start?
Brickman
Old Feb 9, 2006 | 11:52 PM
ITS SOUNDS LIKE THE CAR IS MIS FIRING PROBABLY BA D WIRES TRY SPRAYING WIRES WITH LIGHT MIST OF WATER AND SEE IF THEY SPARK IF SO REPLACE THEM ALSO YOU HAVE A TIMING BELT NOT A CHAIN AND THEY DONT JUMP THEY ONLY BREAK HOPE THIS HELPS LET ME KNOW
Old Feb 15, 2006 | 09:21 PM
brickman's Avatar
Thanks, will try it.
Old Aug 6, 2006 | 05:34 PM
Vtec-asskicker's Avatar
also try the disturbitorcap bad plugs and or wires. try cleaning out the ignition wire with some acetone could have settement deposits the is causing a bad connection.
drterp1986
Jan 31, 2011 06:04 PM
014EVER
Jan 18, 2009 08:35 PM
eubank
Jul 24, 2007 10:27 AM
jinroh
Apr 14, 2007 11:38 AM
MN250R1
Jul 16, 2005 11:45 PM
