97 Sable GS starting trouble
Old Dec 29, 2004 | 01:06 AM
pastorchuck's Avatar
When the car is cold it starts right up, but after it has been driven for a while it becomes difficult to start a few minutes after it has been shut off. I have recently replaced the spark plugs and wires. Might it be the oxygen censor?
Thanks
Chuck
Old Jan 2, 2005 | 04:57 PM
Thats a difficult one to help with, There are so many reasons that could cause that problem from electrical to mechanical you may want to havea properly trained professional take a look at that one..
Old Feb 2, 2005 | 04:48 PM
ugothim's Avatar
if it drags or the starter turns slowly check for a bad starter they tend to drag when hot. if it spins over at normal speed ..then check the ignition control module..[img]smileys/smiley1.gif[/img]
Old Feb 7, 2005 | 11:46 PM
Sounds like your starter turns but the
car dont start ? If so check destrebuter
or the coil and check connections .
then go the a Professional like MercAdvisor
said .
Old Feb 10, 2005 | 04:31 PM
Check to see if you have a UIM leak (upper intake manifold),only shows when warm due to air press/and temp.
moonjaw
Jun 21, 2015 12:10 PM
ansky926
Oct 14, 2011 10:34 AM
snowblind109
Feb 7, 2008 10:53 PM
meatball31
Jan 17, 2008 09:38 PM
beerslinger28
Dec 21, 2005 01:04 AM
