Serpentine Belt Replacement
Old Mar 25, 2006 | 06:07 PM
rickmichaels's Avatar
I just bought a new serpentine belt for my 1996 Mercury Sable DOHC
because my current belt is looking very cracked and old. I found
the diagram on the hood for the belt placement but I'm not sure on how
to replace the belt and tension it.. Can anyone steer me with
some directions?? Thanks!!
Old Mar 29, 2006 | 06:54 PM
look for the spring loaded tensioner pulley, put a decent size wrench to it and that will give you the needed slack.
Old Mar 30, 2006 | 06:14 AM
sinned's Avatar
If you haven't done it yet replace the bearing in this tension pulley. The bearing in mine froze and broke the belt. Also be sure you have the right belt, but you will have to have the correct motor size to check this
Old Apr 13, 2006 | 11:52 AM
there ara only two engine options for that year, the 3.0 Vulcan (crap) and the 3.0 24V Duratec (excellent). So tell your local parts guy which one you have and if you have a/c or not. Then you'll be sure you have the right belt.
Old Apr 19, 2006 | 12:04 AM
THE TENSIONER IS LOCATED TOWARD THE BACK OF THE FIREWALL BETWEEN THE ALT AND THE CRANK PULLEY YOU WILL HAVE TO GET IT FROM THE BOTTOM GOOD LUCK
mrrotary
Jun 25, 2013 04:38 PM
searchlight4759
Aug 3, 2012 11:27 PM
trailhand
May 19, 2010 01:08 AM
bkatzman
Nov 21, 2009 04:32 AM
misteral
May 2, 2009 05:21 PM
