Go Back   Mercury Forum - Mercury Enthusiasts Forums > Vehicle Line Up > Grand Marquis
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 04-25-2013, 04:17 PM
wohara wohara is offline
Question 1998 P0420 Code
My OBD2 code reader is telling me that I have a Catalyst System Efficiency Below Threshold (Bank 1).
Which side is Bank 1? Driver or passenger?
While searching on the internet I found the following:
*Leaded fuel was used where unleaded was called for
*A damaged or failed oxygen sensor (HO2S) Downstream oxygen sensor (HO2S) wiring damaged or connected improperly
*The engine coolant temperature sensor is not working properly
*Damaged or leaking exhaust manifold / catalytic converter / muffler / exhaust pipe
*Retarded spark timing
*The oxygen sensors in front and behind the converter are reporting too similar of readings
*Leaking fuel injector or high fuel pressure
*Cylinder misfire
*Oil contamination
I know for sure my coolant temp sensor is not working but the electric fan turns on and off. Must be a separate temp switch!?
I checked for an exhaust leak by tightening the bolts on the exhaust manifold and found a broken one on the driver side closest to the firewall. On the same side, I also noticed a small oil leak coming from a plugged port on the head just above the exhaust manifold flange. It is dripping right onto the flange.
Looks like I found the Trifecta of problems....if Bank 1 is the Driverside.
Any help would be appreciated
Tags
0420, 1998, bad, bank, check, code, contaminated, engine, grand, marquis, mercury, monterey, oil, p0420, sable, sensor, signs
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
Our Sponsors
Internet Brands, Inc.
