AX4S Problems 94 sable
Old Feb 20, 2005 | 12:19 AM
What they dont tell you could save
you from getting a new transmission.
http://www.transmissionspecialty.com...ts/96201-01K.h tm
Follow this link to learn more.
Old Feb 22, 2005 | 11:22 PM
I have a 94 sable with the ax4s
when i stop the car at a stop sign
the trany doesn't reengage until i
tap the gas then it clunks in gear
any ideas?
Old Feb 24, 2005 | 01:07 PM
Going to check the tps . Has something to do with the Turk converter lock up.
Old Mar 1, 2005 | 12:29 AM
Boost Valve,Forward Control Valve,Servo Tube Bracket,Low Radius Relief Valve,Bypass Clutch Control Valve,Retainer clips, The Surecure
Maybe that will fix my stuped transmission
link http://www.transmissionspecialty.com/parts/PDF/SC-AXOD-E.pdf
Old Mar 29, 2005 | 09:37 PM
Well this is the low down 2256.20 wow but this is the list
1 assembly set-ls-w/.070 intermediate steels(b) 217.11
1 filter-2nd design(b)==================15. 41
1 band-overdrive(b)= ================ 15.83
1 band overdrive(b) ?================= 20.03
13 fluid(b) ;&nbsp ; ; ; ; ; ;==================== 68.25
7.5 labor(rr)(b) =====================525.00
8.4 labor(r)(b) ;===================== 588.00
1 torque converter====================3 29.00
1 chain-drive assembly(chainstre tched)====99.43
1 piston-forward clutch(was cracked)=======21.00
1 planet-ary(was comming apart)=========55.00
1 solenoid-L/u (milege)=========51.00
1 solenoid-pressure control&nbsp ; ; ; ; ; ;"======== 51.00
3 solenoid-shift ;&nbsp ; ; ; ; ; ;" ;&nbsp ; ; ; ; ; ;=====136.08
1 sprag clutch-low clutch sprag ;&nbsp ; ; ; ; ; ;======45.00
1 roller clutch-direct clutch roller ;&nbsp ; ; ; ; ; ;======31.00
1 vb kit-shift kit-transgo(updated Vbody lubeholes)==66.00
tax====================================61. 00
cupone (100.00)cupon from web== -139.00
total parts========================= ==1221.14
labor ;&nbsp ; ; ; ; ;==========================974.00
total ;&nbsp ; ; ; ; ; ========================== 2256.20Edited by: Windzer
Old Mar 31, 2005 | 02:22 PM
Patrick's Avatar
is it fixed now??
Old Apr 1, 2005 | 12:10 AM
Yes a ok
wbsteele
Nov 26, 2008 11:37 PM
SleeperFan
Feb 9, 2007 12:54 PM
Xcopy-
Nov 24, 2006 10:25 AM
imagethree16
Jun 27, 2006 11:51 PM
jennck35
Dec 29, 2005 11:20 PM
