Capri Discuss the Mercury Capri here...
’’91 Capri Cig. Lighter fuse location
Old 12-05-2008, 01:58 PM
Trying to find the cig. lighter fuse on my ''91 Capri. Checked all the fuses under the dash above my left foot but all check OK.
Help?
Old 12-05-2008, 05:41 PM
are you sure it''s a fuse problem? have you checked the wiring? Is the cig lighter rusted/corroded?
Old 12-08-2008, 06:38 AM
The lighter never gets used. I wanted to plug in an inverter to power a laptop. It is also tied to the power locks. There is no lock switch inside. When you unlock or lock one lock, the other lock would actuate. Neither has worked since the lighter stopped working so I suppose they share the same circut.
Old 12-08-2008, 12:35 PM
or they share the same ground to the chassis and that bolt has come loose. if all the fuses check out, you may have to do some wire chasing.
Old 12-08-2008, 01:49 PM
Good point on the ground. I''ll check.
Thanks
frtillman
07-05-2010 01:01 PM
ref2coach
12-09-2009 09:31 PM
mabney007
02-12-2009 03:26 PM
Flominator
07-22-2006 09:32 AM
jollyjohnj
02-21-2006 11:04 AM
Quick Reply: ’’91 Capri Cig. Lighter fuse location
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
