-   -   93 Cougar door hinge pin replacement (https://www.mercuryforum.com/forum/cougar-18/93-cougar-door-hinge-pin-replacement-3072/)
93cougarboy Jul 6, 2009 05:17 PM
I found the pins, bushings, etc... The problem is that I have no idea how to replace the old one without taking the door off. Is there any way to avoid this? Any help is greatly appreciated. Thanks
slymer Jul 6, 2009 06:48 PM
I used a hammer and a large screw driver to bang out the pins that the bushings are mounted on, but that was on a 85 pontiac parisienne. I'm not sure about the older cougar though.
maxfax3 Jul 6, 2009 08:53 PM
If you do one hinge at a time and support the door it can be done.. Although I think it's maybe a tad easier to just take the door off...
Bobbydsp Oct 15, 2014 04:40 PM
Slymer, look on the internet for instruction videos. U-tube has a lot of them. I did my left top pin by using a Dremel grinder to grind the top off the pin and driving it out with a punch.. I did my right side door pin by simply loosening the bolts on the hinge and inserting shims. My shims were suspension ones like wheel alignment people use on the a-arms. Worked perfectly.
Bobbydsp
