93 with lights acting up
on my 93 xr-7, at first the lights will stay on just fine but after about 10 to 15 minutes the lights go off and come back on randomly. but if i push the turn signel forward they do the same thing, but if i pull back the highs stay on and the lows flash on and off. does anybody know what is wrong?
thanks
There is A built in circuit breaker in the headlight switch. It could be weak. When you pull back on the turn signal switch, Is that the flash to pass position? I think the high beam's bypass the headlight switch in that position.
Bellwether11
Mar 15, 2013 02:51 PM
