Cougar lights diming in and out
Old Jul 23, 2007 | 11:44 AM
pitmaster's Avatar
Hey guys im new here, i have a 99 mercury cougar v6, and my problem is this.
The lights all of them, head, interior ect, dim in and out, now i know its not the alternator because it has been checked and is working fine, im not to sure what else it could be any suggestions or has anyone come across this problem too? thanks
Old Jul 25, 2007 | 01:24 PM
danielhaumann06's Avatar
I had the same problem. I also have a 99 cougar. Turns out it was a connection between the alternator and the battery. That is why everything looks okay when your alternator gets checked. Hope this helps.
Old Jul 25, 2007 | 03:31 PM
pitmaster's Avatar
How was it fixed? what did you replace? thanks a lot for the tip.
Old Sep 20, 2007 | 12:20 AM
cougarowner's Avatar
wow...my 99 also has the same problem...every now and then they'll start to do that. although i haven't gotten mine checked yet.
Old Jul 2, 2008 | 09:46 AM
scott89racin's Avatar
Its the cable between the alt and the battery. try cleaning it first as this usually fixes it. if not you will need to get a new cable assy from Mercury.Dont bother with aftermarket stuff it will be more hassle and wont look/fit right.
Old Jul 13, 2008 | 12:13 PM
00CougarGirl00's Avatar
The problem was reported to dealers under a technical service bulletin, under the number TSB 00-25-06 and then was updated to include more models of cars under TSB 01-10-12. The following links will take you to copies of the tsb''s. if the links don''t work then cut and paste them into your browser. Hope this helps.
www.teamwetworks.com/claymore/cougar/<WBR>tsb00-25-06.pdf
click on the next web site and there is a link on that page for the pdf version of the tsb 01-10-12
http://www.thedieselstop.com/faq/949...sb/01-10-12.ph p3
Old Jul 23, 2008 | 12:56 PM
conan312's Avatar
Go CougarGirl!!!
Old Nov 23, 2008 | 04:08 PM
jeremy18's Avatar
I also have this problem on my girlfriends 00 V6. Is the problem that the cable is routed wrong? What is the exact steps to fix this problem what all is needing cleaning? I would like to get this done for her because it flickers pretty good. Thanks everyoen
Old Nov 23, 2008 | 10:16 PM
  #9
Jeremy if u go to the service bulletins I spoke about in my post back in July they will tell you exactly how to fix the flickering. Apparently there is a part of the wiring that needs to be cut out and you also need to buy a part that should only cost you 15 to 20 bucks depending where u buy it. I took the copies of the bullentins to a friend of mine and he was able to fix it with no problem, he said its an easy fix.Hope this helps.
http://www.thedieselstop.com/faq/9497faq/tsb/tsb/01-10-12.ph p3
Old Nov 24, 2008 | 11:43 AM
  #10
jeremy18's Avatar
So your taking the wire out of the power distribution box and putting a ring connector on it and hooking it up to the alternator. Correct? Sounds like all is needed is a ring connector. Might be wrong anyone got any pics please or a write up.
Copied: Reroute the battery sense line from the engine compartment power distribution box to the B+ terminal on the alternator.
Bobbydsp
Oct 15, 2014 12:53 PM
Bellwether11
Mar 15, 2013 02:51 PM
Joninray
Oct 17, 2011 09:49 PM
snowycoma2007
Nov 15, 2008 09:24 PM
97merc
Jul 24, 2006 03:40 PM
