European tail lights
Old Apr 23, 2009 | 12:55 PM
sharpb1's Avatar
Default European tail lights
Help installing them...just the wiring.
Old Apr 23, 2009 | 04:43 PM
make, model of car installing on and pulled from please.
Old Apr 23, 2009 | 08:11 PM
sharpb1's Avatar
year of the car is 2000. the european lights fit any 99-02 i believe. im just not sure which lights go where because the turn signal is moved from the far right to the new amber light on the european model, but on the us model the turn signal and the running lights are on the same bulb. i don't want the amber light being my running light, that would not look right.
Old Apr 24, 2009 | 07:31 AM
ah
the easiest way to figure out which wire is which is to get a multimeter and take the bulb out, turn on the parking lights and see which wire has 12V on it. then turn on the blinker and see which one has 12V intermittently. The other will be ground. Mark them, splice them, reconnect, plug in and go!
Old Apr 24, 2009 | 01:44 PM
sharpb1's Avatar
i got them installed and everything. thanks for your help. but somehow in the process i blew the break fuse because the break lights do not come on and the car is stuck in park unless i manually move the lever to get it out of park but then my break lights are still not lighting. im hoping it's the fuse?
zarniro
Sep 30, 2010 06:16 AM
mawwam
May 2, 2010 03:42 AM
iJay
Jan 30, 2009 09:55 AM
89 marquis
Mar 7, 2008 10:21 AM
baraby1969
Feb 8, 2006 02:03 PM
