slymer |
12-04-2008 10:03 PM |
check the ductwork. make sure there''s not a bag up against the heater core. you may also need to take out the heater core and make sure it''s actually flowing coolant through it. If there''s no flow, it''ll never warm up to be able to supply heat. If it''s like my MGM and has a vacuum controlled valve to cut off the flow to the heater core, you''ll have to check out the vacuum lines to make sure they''re all working right. There''s a lot of possibilities for this issue. Happy hunting [img]smileys/smiley5.gif[/img]
