Power Steering pump flush
On my 97, the steering is hard when cold.. Was thinking on changing out fluid (dirty) and using Mobil 1 syn. (mercon atf).. What's the best way to flush the system..?
the best way would be to have plenty on hand and disconnect the return tube and have it pump into a bucket (waste bin, etc). have someone turn the car on and pour fresh fluid in until the stuff coming out is clear. Then turn the car off, reconnect the return line and top it off.
I would suggest using power steering fluid though and maybe putting a filter inline with the return line (with the flow in the right direction of course) as that would probably be better for the system than using a fluid that the system wasn't designed to use. Of course, that's up to you. If the fluid you're adding is not clear, then of course you want to see whatever color it is coming out of the return line during the flushing process. you may need a gallon or 2 for the entire flush depending on how dirty the system is. and yes, you flush with the new fluid. There might be some power steering flush concoctions at the parts store, but I've never heard of anyone using them. I'm sure if someone else here has any better ideas, they'll post them. |
When it is cold out the oil tends to thicken up and thus is a little slower to pump through the system which is why you are experiencing stiffness. As it warms, the fluid thins out and its viscosity returns to normal and the steering loosens up. I would flush it like Slymer said but watch out for the high pressure, yes, even on the return hose when you start the engine. GUSH!!!
Originally Posted by slymer
(Post 9146)
One is a sending line (very high pressure, and expensive) should look abit different than the return line (much less pressure and much cheaper to replace). Big reinforced, crimped metal ends, etc. I don't know right or left without seeing. Hopefully you will be able to tell. Hey, if you unhook the return line from the pump make sure and cap the pump inlet. The manual is correct. Alot of cars use trans fluid as p.s. fluid.
yeah... I forgot that... the manual for my MGM says any type F fluid (ATF, Power Steering Fluid, etc).
I need to replace the pump on mine. it has a leak out the high pressure line before the hose fitting. |
Thanks to ya all for the info.. I got her flushed and it working alot better..
