No luck with a search here. Any idea where to get a Proportioning Valve (Brakes) for an ''86 Cougar. The part is obsolete. Not very good at searching for parts but, I tried searching for a used part with no luck. Would any other Mfg. part work in it''s place? Thanks Peter |
Yes, there are aftermarket parts. you might have to bend a few lines to make it fit because they are not exact replacement parts. here are a few. you can also do a search on mustang parts for that year. they will also fit summit racing jegs jc witney |
Jason, Thank you. I will look into your lead and mentionit to my mechanic. How would you know what other valves would work even with the need to bend a few lines? What would we look for? I was thinking that looking for used ''83-''86 Cougars and T-Birds would expand my possibilities also. Wouldn''t that be logical? Again,Thank You. PeterF. |
Are you doing some racing with this? are you looking for an fully adjustable one?
1986-96 Ford, Lincoln Town Car and Mercury full-size cars o 1986-97 Cougar, Lincoln Mark series and Thunderbird o 1986-96 Mustang o 1984-86 Capri o 1990-97 Aerostar Van with WDA or WFB axles o 1983-96 Bronco (rear) with WDR or WFL axles o 1987-96 Bronco (rear) with WFH or WDB axles o 1997-01 Mercury Mountaineer o 1991-01 Explorer o 1986-99 Ranger with WDG or WFG axles o 1983-99 E150 Vans with WEC or WFV axles o 1983-89 E250 Vans with WEC or WFS axles o 1983-85 Ranger with WDR or WFL axles o 1983-97 F150 o 1983-85 F250 o 1993-98 Mazda B4000 o 1991-94 Mazda Navajo you can get used ones from these or order new ones. make sure it is what you want before getting it. take a picture of yours or just bring the old one in.Edited by: jason sereiko |
I hope the list helps. I would just do the aftermarket thing if you have a mechanic and can not find the part. I assume you are looking for a new part with the other cars. Make sure you get the correct one because some cars or trucks, came with tow packages and some did not. they would have different parts. so would a 4 banger compared to a small block let me know if this worksEdited by: jason sereiko |
Jason, That''s great. I will drop this whole print out off with my mechanic and update as soon as I can. Thank you. PeterF |
Jason, No racing. Just trying to this old cat purring. I am the original owner and it''s in very good + condition. I hope to get it to it''s historic date. Thanks for helping. Peter |
try classic tube. www.classictube.com they sell pre bent tubes,brake and fuel lines. 1800-882-3711 or call them. they might know how to get your part |
