I have Water in Exhaust, Bubbles in Radiator, and gas smell in radiator in 95 cougar 4.6 I have beentold head gasket and also if I was lucky it could be an intake gasket. Any help???[img]smileys/smiley7.gif[/img]
It is probably a cracked intake manifold. The EGR(exhaust gas recirculation)port is known to crack or coorode. It is supposed to be cooled by coolant so if the two passages come in contact with each other they cause this problem. If you had a blown head gasket you would be blowing white, puffy smoke out the tail pipe and would be over heating badly.
