grand marquis locksmith help
Since last few days my rear left door lock was getting jammed and was not locking. The lock lever didn’t go down when we lock the car. So I had to manually press it down and lock it. But since last 2 days now my front left door lock is also behaving same way. Now only my right door locks work well. Should I call a locksmith?
Yep.. call a locksmith
Not sure a locksmith is going to help you. They don't generally work on cars. Seems to me it's more of an electrical problem with the master window board on the driver's door. I'm assuming you have power locks? My first course of action would be to pull the switch and clean the contacts.
Maybe a locksmith can help but not sure about it. According to me consulting this problem with the dealer is a suitable option.
I agree with everyone hiring a locksmith is the best solution to this problem. They will easily remove the lever without damaging it.
I agree with you, a locksmith doesn't work on cars earlier but nowadays locksmith works on car locks also. So, you can rely on them for such issues.
Originally Posted by lapmhaten
(Post 19673)
Use Lukewarm water over it and see whether it work or not if not then think of hiring an auto locksmith.
I am not sure about it maybe a locksmith can help you with it but mostly all prefer dealers for that problem.
