-   Engine & Internal (https://www.mercuryforum.com/forum/engine-internal-30/)
-   -   1992 marquis 4.6L I want more power (https://www.mercuryforum.com/forum/engine-internal-30/1992-marquis-4-6l-i-want-more-power-659/)
92mercurygm Jul 20, 2006 06:58 PM
Hey every body.I have a 1992 Grand Marquis,with a 4.6LSOHC V8.and I wanted to knowwhatthe best way to get more horse power.I am puting dual exaust with about 18"long glasspacks on it and I am going toget a cold air intake kit too.Iwanted to get achip for it but I dont knowwere the best place is to get one that will worklike it should.Ihave seen the ones on ebayforaround$15butI didn't know ifthey realy workas goodthey say it does.
Thanks,JustinEdited by: 92mercurygm
94cougarxr7 Aug 17, 2011 07:12 PM
there is a couple for the mustang 4.6 v8 should work because it is the same engine but tame and more efecent compared to the mustangs full power perks i have coming a intake manifold coming from tric flow they have a good intake manifold and i am getting headers and x pyps installed later on my cougar i just wanted to give you a heads up
speedyred Aug 28, 2011 12:41 PM
If you want a chip try fgchips.com and type the year and model of your car. their site says that the chips are supposed to give you 60 hp, 4-7 mpg, and 25-40% less emissions for about $ 70.
speedyred Aug 28, 2011 12:44 PM
and on thosmufflers I think they might be a bit louder than you will want on a car like this. look on jegs.com and for a set of pypes m80 mufflers and if you want to see what they sound like look on youtube and type in pypes m80 mufflers mustang.
87_Crown_Vic Aug 30, 2011 01:46 AM
this chip company looks to be a scam... do a review for the company... found many who barely gained and more who lost mileage, and in most cases less than 10 hp gain... cheap chips or no brand ones only reprogram to lean out the system, and trick computer how it senses the coolant temperature... doing this messes up engine more than helping
speedyred Aug 30, 2011 07:31 PM
you could try autochipsdirect.com
speedyred Sep 1, 2011 11:55 AM
you could also try rpmoutlet.com or find a 1999-2004 mustang gt or crown vic or gm with a 4.6L and get the heads off of it they are called PI (Power Improvement) heads and the intake manifold that could give you some serious power. they are about 800 bucks a set from that website or you could pick a used set for around 200 or so depends on the mileage of the engine.
mikethomsun Sep 2, 2011 01:25 AM
I suggest you to try for rennlist.com, you can get more information about the chip. I hope that you get this soon.
