engine modification ideas...
i have a 1987 Grand Marquis with a 5.0L and a 3.27 trac-lok rearend. i plan on installing a HO cam, changing cylinder heads to some GT40s, swapping the upper intake/plenum, and putting on some shorty headers connected to a H pipe.
thought i would put something in here since it is filled with SPAM!!!
What an amazing sleeper that car could make. You thinking about a Ford cam? I think the B303 would be perfect for your app.
Probably the most overlooked part in 5.0 builds is the fuel system. A big azz fuel pump with larger feed and return lines and some 24lb injectors will really wake it up with a little tuning. Is the 87 Merc 5.0 a mass air stsem or speed density? If it's mass air you'll want to upsize trhe MAF and throttle body too....If you haven't already.
i have a pair of 1987 Crown Vic 2 doors i am going to build up. my first 2 door i got will get a 1997 Explorer/Mountaineer 5.0L since it is a H.O. setup and would only need to swap the computer/ECM, do the shorty headers, connected to the offroad "X" pipe i have and install the Typhoon upper and lower intake set i have. my cars are at a standstill at present due to just moving and needing to find a job.
If you go with the 24ibs, then you have to use a stock cobra mass air flow unless you get an adjustable one that is very expensive. I am doing the sam build for real and I am almost done. the trick is getting something in the budget and something that you can add parts to without having to completley change the computer, thats why I say run a program from www.moates.com for all of the racing computer stuff.
<TABLE cellSpacing=3 cellPadding=2>
<T>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>Here it is Guys</TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>
<H1 class="font_large color_1 bold">The Mutt - Over 500hp and 565 lb-ft from Ford''s small block</H1>
<DIV class="" id=ctl00_ctl08_ctl00_lblArticle>
<T>
<TR>
<TD>DESCRIPTION</TD>
<TD>Manufacturer </TD>
<TD>PN</TD>
<TD>source</TD>
<TD>Amount</TD>
<TD>Price</TD></TR>
<TR>
<TD>Donor engine</TD>
<TD>Ford</TD>
<TD></TD>
<TD>Junkyard</TD>
<TD>1</TD>
<TD>$150.00</TD></TR>
<TR>
<TD>Valve covers</TD>
<TD>Ford</TD>
<TD></TD>
<TD>Junkyard</TD>
<TD>1</TD>
<TD>15.00</TD></TR>
<TR>
<TD>Stroke crank</TD>
<TD>KES</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>150.00</TD></TR>
<TR>
<TD>Machine work</TD>
<TD>KT Engines</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>1,000.00</TD></TR>
<TR>
<TD>pistons</TD>
<TD>KB</TD>
<TD>KB243</TD>
<TD>Summit Racing</TD>
<TD>8</TD>
<TD>220.69</TD></TR>
<TR>
<TD>Rings</TD>
<TD>Sealed Power</TD>
<TD>E251K40</TD>
<TD>Summit racing</TD>
<TD>8</TD>
<TD>35.95</TD></TR>
<TR>
<TD>Water pump</TD>
<TD></TD>
<TD>WP399</TD>
<TD>Advance Auto Parts</TD>
<TD>1</TD>
<TD>29.88</TD></TR>
<TR>
<TD>Gasket kit</TD>
<TD>Fel-Pro</TD>
<TD>FEL-KS2308</TD>
<TD>1</TD>
<TD>52.95</TD></TR>
<TR>
<TD>Intake gaskets</TD>
<TD>Fel-Pro</TD>
<TD>FEL-1240</TD>
<TD>1</TD>
<TD>16.95</TD></TR>
<TR>
<TD>Heads</TD>
<TD>Edelbrock</TD>
<TD>61629</TD>
<TD>2</TD>
<TD>1,818.78</TD></TR>
<TR>
<TD>Valvesprings</TD>
<TD>Comp Cams</TD>
<TD>929-16</TD>
<TD>1</TD>
<TD>136.95</TD></TR>
<TR>
<TD>Intake manifold</TD>
<TD>Edelbrock</TD>
<TD>2171</TD>
<TD>1</TD>
<TD>194.88</TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD>Oil pan</TD>
<TD>Milodon</TD>
<TD>30927</TD>
<TD>1</TD>
<TD>232.95</TD></TR>
<TR>
<TD>Oil pump</TD>
<TD>Melling</TD>
<TD>M84A</TD>
<TD>1</TD>
<TD>28.88</TD></TR>
<TR>
<TD>Oil-pump shaft</TD>
<TD>Clevite</TD>
<TD>6011431</TD>
<TD>1</TD>
<TD>4.49</TD></TR>
<TR>
<TD>Oil-pump pickup</TD>
<TD>Milodon</TD>
<TD>18355</TD>
<TD>1</TD>
<TD>37.95</TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD>ARP head bolts</TD>
<TD>ARP</TD>
<TD>154-3604</TD>
<TD>1</TD>
<TD>57.95</TD></TR>
<TR>
<TD>Timing chain </TD>
<TD>KT3-498SA2</TD>
<TD>1</TD>
<TD>23.99</TD></TR>
<TR>
<TD>Forged con rods</TD>
<TD>K1 Technologies</TD>
<TD>CH6300ALLBS</TD>
<TD>Central High</TD>
<TD>8</TD>
<TD>399.46</TD></TR>
<TR>
<TD>Crane roller cam</TD>
<TD></TD>
<TD>52HR00032</TD>
<TD>Crane Cams</TD>
<TD>1</TD>
<TD>360.00</TD></TR>
<TR>
<TD>Roller lifters</TD>
<TD>Ford</TD>
<TD>M-6500-R302</TD>
<TD>16</TD>
<TD>119.95</TD></TR>
<TR>
<TD>Lifter adapter plate</TD>
<TD>Comp</TD>
<TD>31-1000</TD>
<TD>1</TD>
<TD>49.39</TD></TR>
<TR>
<TD>Pushrods</TD>
<TD>CV Products</TD>
<TD>8.750 x 5/16</TD>
<TD>16</TD>
<TD>123.04</TD></TR>
<TR>
<TD>Rocker arms</TD>
<TD>Crane Energizer</TD>
<TD>13744-16</TD>
<TD>16</TD>
<TD>195.95</TD></TR>
<TR>
<TD>Main bearings</TD>
<TD>5078M1</TD>
<TD>1</TD>
<TD>23.48</TD></TR>
<TR>
<TD>Cam bearings</TD>
<TD>1403M</TD>
<TD>1</TD>
<TD>17.77</TD></TR>
<TR>
<TD>Rod bearings</TD>
<TD>Clevite</TD>
<TD>CB-1227 P</TD>
<TD>8</TD>
<TD>83.12</TD></TR>
<TR>
<TD>Distributor</TD>
<TD>MSD</TD>
<TD>8580</TD>
<TD>1</TD>
<TD>225.95</TD></TR>
<TR>
<TD>Wires</TD>
<TD>MSD</TD>
<TD>31339</TD>
<TD>1</TD>
<TD>78.88</TD></TR>
<TR>
<TD>Coil</TD>
<TD>MSD</TD>
<TD>8202</TD>
<TD>1</TD>
<TD>34.88</TD></TR>
<TR>
<TD>Plugs</TD>
<TD>Autolight</TD>
<TD>3924</TD>
<TD>8</TD>
<TD>21.44</TD></TR>
<TR>
<TD>Header</TD>
<TD>Dynomax</TD>
<TD>WLK-85064</TD>
<TD>1</TD>
<TD>135.95</TD></TR>
<TR>
<TD>Damper</TD>
<TD></TD>
<TD>15950147</TD>
<TD>1</TD>
<TD>59.88</TD></TR>
<TR>
<TD>Flexplate</TD>
<TD></TD>
<TD>2922510</TD>
<TD>1</TD>
<TD>47.97</TD></TR>
<TR>
<TD>Paint</TD>
<TD>Dupli-color</TD>
<TD>Ford Blue & Silver</TD>
<TD>2</TD>
<TD>8.80</TD></TR>
<TR>
<TD>Fan spacer</TD>
<TD></TD>
<TD>252012</TD>
<TD>1</TD>
<TD>8.88</TD></TR>
<TR>
<TD>Oil</TD>
<TD>Valvoline</TD>
<TD>5W30 (4 qt bottle)</TD>
<TD>2</TD>
<TD>21.56</TD></TR>
<TR>
<TD>Misc. bolts</TD>
<TD></TD>
<TD></TD>
<TD>KT Engines</TD>
<TD></TD>
<TD>50.00</TD></TR>
<TR>
<TD>Oil filter</TD>
<TD>Fram</TD>
<TD>PH8A</TD>
<TD>1</TD>
<TD>3.88</TD></TR>
<TR>
<TD>Total</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>$6,772.74</TD></TR>
<TR>
<TD colSpan=6>Extras</TD></TR>
<TR>
<TD>Piston-notching tool</TD>
<TD>Isky</TD>
<TD>PNT-216</TD>
<TD>Isky</TD>
<TD>1</TD>
<TD>40.00</TD></TR>
<TR>
<TD>Edelbrock</TD>
<TD>4461</TD>
<TD>1</TD>
<TD>39.88</TD></TR>
<TR>
<TD>Total</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR></T></TABLE></DIV>
<DIV style="CLEAR: both">
<HR id=ctl00_ctl08_ctl00_hr>
</DIV></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD colSpan=6></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
</HR></DIV>
<T>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD>
<T>
<TR>
<TD>PN</TD>
<TD>source</TD>
<TD>Amount</TD>
<TD>Price</TD></TR>
<TR>
<TD>Ford</TD>
<TD></TD>
<TD>Junkyard</TD>
<TD>1</TD>
<TR>
<TD>Ford</TD>
<TD></TD>
<TD>Junkyard</TD>
<TD>1</TD>
<TD>15.00</TD></TR>
<TR>
<TD>KES</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TR>
<TD>KT Engines</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TR>
<TD>pistons</TD>
<TD>KB</TD>
<TD>KB243</TD>
<TD>8</TD>
<TR>
<TD>Rings</TD>
<TD>E251K40</TD>
<TD>8</TD>
<TD>35.95</TD></TR>
<TR>
<TD>Water pump</TD>
<TD></TD>
<TD>WP399</TD>
<TD>1</TD>
<TD>29.88</TD></TR>
<TR>
<TD>Gasket kit</TD>
<TD>Fel-Pro</TD>
<TD>FEL-KS2308</TD>
<TD>1</TD>
<TD>52.95</TD></TR>
<TR>
<TD>Fel-Pro</TD>
<TD>FEL-1240</TD>
<TD>1</TD>
<TD>16.95</TD></TR>
<TR>
<TD>Heads</TD>
<TD>Edelbrock</TD>
<TD>61629</TD>
<TD>2</TD>
<TR>
<TD>Comp Cams</TD>
<TD>929-16</TD>
<TD>1</TD>
<TR>
<TD>Edelbrock</TD>
<TD>2171</TD>
<TD>1</TD>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD>Oil pan</TD>
<TD>Milodon</TD>
<TD>30927</TD>
<TD>1</TD>
<TR>
<TD>Oil pump</TD>
<TD>Melling</TD>
<TD>M84A</TD>
<TD>1</TD>
<TD>28.88</TD></TR>
<TR>
<TD>Clevite</TD>
<TD>6011431</TD>
<TD>1</TD>
<TD>4.49</TD></TR>
<TR>
<TD>Milodon</TD>
<TD>18355</TD>
<TD>1</TD>
<TD>37.95</TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD>ARP</TD>
<TD>154-3604</TD>
<TD>1</TD>
<TD>57.95</TD></TR>
<TR>
<TD>KT3-498SA2</TD>
<TD>1</TD>
<TD>23.99</TD></TR>
<TR>
<TD>8</TD>
<TR>
<TD></TD>
<TD>52HR00032</TD>
<TD>Crane Cams</TD>
<TD>1</TD>
<TR>
<TD>Ford</TD>
<TD>16</TD>
<TR>
<TD>Comp</TD>
<TD>31-1000</TD>
<TD>1</TD>
<TD>49.39</TD></TR>
<TR>
<TD>Pushrods</TD>
<TD>16</TD>
<TR>
<TD>13744-16</TD>
<TD>16</TD>
<TR>
<TD>5078M1</TD>
<TD>1</TD>
<TD>23.48</TD></TR>
<TR>
<TD>1403M</TD>
<TD>1</TD>
<TD>17.77</TD></TR>
<TR>
<TD>Clevite</TD>
<TD>CB-1227 P</TD>
<TD>8</TD>
<TD>83.12</TD></TR>
<TR>
<TD>MSD</TD>
<TD>8580</TD>
<TD>1</TD>
<TR>
<TD>Wires</TD>
<TD>MSD</TD>
<TD>31339</TD>
<TD>1</TD>
<TD>78.88</TD></TR>
<TR>
<TD>Coil</TD>
<TD>MSD</TD>
<TD>8202</TD>
<TD>1</TD>
<TD>34.88</TD></TR>
<TR>
<TD>Plugs</TD>
<TD>Autolight</TD>
<TD>3924</TD>
<TD>8</TD>
<TD>21.44</TD></TR>
<TR>
<TD>Header</TD>
<TD>Dynomax</TD>
<TD>WLK-85064</TD>
<TD>1</TD>
<TR>
<TD>Damper</TD>
<TD></TD>
<TD>15950147</TD>
<TD>1</TD>
<TD>59.88</TD></TR>
<TR>
<TD>Flexplate</TD>
<TD></TD>
<TD>2922510</TD>
<TD>1</TD>
<TD>47.97</TD></TR>
<TR>
<TD>Paint</TD>
<TD>2</TD>
<TD>8.80</TD></TR>
<TR>
<TD>Fan spacer</TD>
<TD></TD>
<TD>252012</TD>
<TD>1</TD>
<TD>8.88</TD></TR>
<TR>
<TD>Oil</TD>
<TD>Valvoline</TD>
<TD>2</TD>
<TD>21.56</TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD>KT Engines</TD>
<TD></TD>
<TD>50.00</TD></TR>
<TR>
<TD>Oil filter</TD>
<TD>Fram</TD>
<TD>PH8A</TD>
<TD>1</TD>
<TD>3.88</TD></TR>
<TR>
<TD>Total</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TR>
<TR>
<TD>Isky</TD>
<TD>PNT-216</TD>
<TD>Isky</TD>
<TD>1</TD>
<TD>40.00</TD></TR>
<TR>
<TD>Edelbrock</TD>
<TD>4461</TD>
<TD>1</TD>
<TD>39.88</TD></TR>
<TR>
<TD>Total</TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
</DIV></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD></TR>
<TR>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
<TD></TD>
</HR></DIV>
<T>
<TR>
<TD colSpan=3>Dyno Results</TD></TR>
<TR>
<TD>RPM</TD>
<TD>Torque</TD>
<TD>HP</TD></TR>
<TR>
<TD>3,800</TD>
<TD>559.2</TD>
<TD>404.6</TD></TR>
<TR>
<TD>3,900</TD>
<TD>560.8</TD>
<TD>416.5</TD></TR>
<TR>
<TD>4,000</TD>
<TD>562.5</TD>
<TD>428.4</TD></TR>
<TR>
<TD>4,100</TD>
<TD>564.1</TD>
<TD>440.4</TD></TR>
<TR>
<TD>4,200</TD>
<TD>564.4</TD>
<TD>451.4</TD></TR>
<TR>
<TD>4,300</TD>
<TD>565.0</TD>
<TD>462.6</TD></TR>
<TR>
<TD>4,400</TD>
<TD>560.6</TD>
<TD>469.7</TD></TR>
<TR>
<TD>4,500</TD>
<TD>554.2</TD>
<TD>474.9</TD></TR>
<TR>
<TD>4,600</TD>
<TD>550.0</TD>
<TD>481.7</TD></TR>
<TR>
<TD>4,700</TD>
<TD>545.6</TD>
<TD>488.2</TD></TR>
<TR>
<TD>4,800</TD>
<TD>539.7</TD>
<TD>493.2</TD></TR>
<TR>
<TD>4,900</TD>
<TD>532.5</TD>
<TD>496.8</TD></TR>
<TR>
<TD>5,000</TD>
<TD>525.2</TD>
<TD>500.0</TD></TR>
<TR>
<TD>5,100</TD>
<TD>518.7</TD>
<TD>503.7</TD></TR>
<TR>
<TD>5,200</TD>
<TD>507.2</TD>
<TD>502.2</TD></TR>
<TR>
<TD>5,300</TD>
<TD>500.4</TD>
<TD>505.0</TD></TR>
<TR>
<TD>5,400</TD>
<TD>489.9</TD>
<TD>503.6</TD></TR>
<TR>
<TD>5,500</TD>
<TD>482.0</TD>
<TD>504.8</TD></TR>
<TR>
<TD>5,600</TD>
<TD>470.4</TD>
<TD>501.6</TD></TR>
<TR>
<TD>5,700</TD>
<TD>456.4</TD>
<TD>495.4</TD></TR>
<TR>
<TD>5,800</TD>
<TD>445.6</TD>
<TD>492.1</TD></TR>
<TR>
<TD>5,900</TD>
<TD>436.0</TD>
<TD>489.8</TD></TR>
<TR>
<TD>Average</TD>
<TD>522.3</TD>
<TD>477.7</TD></TR></T></TABLE></DIV>
<T>
<TR>
<TR>
<TD>RPM</TD>
<TD>Torque</TD>
<TD>HP</TD></TR>
<TR>
<TD>3,800</TD>
<TD>559.2</TD>
<TD>404.6</TD></TR>
<TR>
<TD>3,900</TD>
<TD>560.8</TD>
<TD>416.5</TD></TR>
<TR>
<TD>4,000</TD>
<TD>562.5</TD>
<TD>428.4</TD></TR>
<TR>
<TD>4,100</TD>
<TD>564.1</TD>
<TD>440.4</TD></TR>
<TR>
<TD>4,200</TD>
<TD>564.4</TD>
<TD>451.4</TD></TR>
<TR>
<TD>4,300</TD>
<TD>565.0</TD>
<TD>462.6</TD></TR>
<TR>
<TD>4,400</TD>
<TD>560.6</TD>
<TD>469.7</TD></TR>
<TR>
<TD>4,500</TD>
<TD>554.2</TD>
<TD>474.9</TD></TR>
<TR>
<TD>4,600</TD>
<TD>550.0</TD>
<TD>481.7</TD></TR>
<TR>
<TD>4,700</TD>
<TD>545.6</TD>
<TD>488.2</TD></TR>
<TR>
<TD>4,800</TD>
<TD>539.7</TD>
<TD>493.2</TD></TR>
<TR>
<TD>4,900</TD>
<TD>532.5</TD>
<TD>496.8</TD></TR>
<TR>
<TD>5,000</TD>
<TD>525.2</TD>
<TD>500.0</TD></TR>
<TR>
<TD>5,100</TD>
<TD>518.7</TD>
<TD>503.7</TD></TR>
<TR>
<TD>5,200</TD>
<TD>507.2</TD>
<TD>502.2</TD></TR>
<TR>
<TD>5,300</TD>
<TD>500.4</TD>
<TD>505.0</TD></TR>
<TR>
<TD>5,400</TD>
<TD>489.9</TD>
<TD>503.6</TD></TR>
<TR>
<TD>5,500</TD>
<TD>482.0</TD>
<TD>504.8</TD></TR>
<TR>
<TD>5,600</TD>
<TD>470.4</TD>
<TD>501.6</TD></TR>
<TR>
<TD>5,700</TD>
<TD>456.4</TD>
<TD>495.4</TD></TR>
<TR>
<TD>5,800</TD>
<TD>445.6</TD>
<TD>492.1</TD></TR>
<TR>
<TD>5,900</TD>
<TD>436.0</TD>
<TD>489.8</TD></TR>
<TR>
<TD>Average</TD>
<TD>522.3</TD>
<DIV class=skin1_er_article>
<DIV class=skin_er_text_article>Ford Daily Driver Performance - Build a Killer Daily Driver. This is a budget you can do.</DIV></DIV>
<DIV class="padding_right padding_top border_sides image_border">
<DIV class=_link id=ctl00_ctl08_ctl00_lblArticle>
<DIV style="PADDING-RIGHT: 4px; PADDING-LEFT: 4px; FLOAT: right; PADDING-BOTTOM: 4px; WIDTH: 150px; PADDING-TOP: 4px">
Since bench racing is an important part. With 350 lb-ft of torque at 4,000 rpm and 355 hp at 6,000 rpm, </DIV>
<TABLE cellSpacing=2 border=1 CELLPADING="2">
<T>
<TR>
<TD align=middle colSpan=3>Baseline engine</TD></TR>
<TR>
<TD colSpan=3>
<LI>575-cfm factory Holley carburetor
<LI>OE headers, single-cat piping, dual mufflers
<LI>Factory intake manifold
<LI>35 degrees total timing</LI></TD></TR>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>246</TD>
<TD>118</TD></TR>
<TR>
<TD>3,000</TD>
<TD>254</TD>
<TD>146</TD></TR>
<TR>
<TD>3,200</TD>
<TD>256</TD>
<TD>158</TD></TR>
<TR>
<TD>3,500</TD>
<TD>255</TD>
<TD>171</TD></TR>
<TR>
<TD>4,000</TD>
<TD>240</TD>
<TD>183</TD></TR>
<TR>
<TD>4,400</TD>
<TD>223</TD>
<TD>188
<TR>
<TD>4,500</TD>
<TD>219</TD>
<TD>188</TD></TR>
<TR>
<TD>5,000</TD>
<TD>193</TD>
<TD>184</TD></TR>
<TR>
<TD>5,500</TD>
<TD>160</TD>
<TD>168</TD></TR>
<TR>
<TD>6,000</TD>
<TD>N/A</TD>
<TD>N/A</TD></TR>
<TR>
<TD colSpan=3></TD></TR>
<TR>
<TD colSpan=3>*Westech SuperFlow chassis dyno</TD></TR></T></TABLE>
Clean-burning cylinders require optimum spark energy. MSD set us up with its 6AL rev-limiting ignition box, Blaster 2 coil, spiral core wires with Pro-Clamp separators, and an in-car ignition retard/advance box to promote optimum fuel mileage.</DIV>
<T>
<TR>
<TD align=middle colSpan=3>50-state smog-legal rebuilt engine
<TR>
<TD colSpan=3>
<LI>1-5/8-inch FlowTech header
<LI>Performer intake manifold
<LI>33 degrees total timing</LI></TD></TR>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>294</TD>
<TD>140</TD></TR>
<TR>
<TD>3,000</TD>
<TD>306</TD>
<TD>175</TD></TR>
<TR>
<TD>3,500</TD>
<TD>313</TD>
<TD>209</TD></TR>
<TR>
<TD>3,600</TD>
<TD>337</TD>
<TD>232
<TR>
<TD>4,000</TD>
<TD>336</TD>
<TD>256</TD></TR>
<TR>
<TD>4,500</TD>
<TD>330</TD>
<TD>283</TD></TR>
<TR>
<TD>5,000</TD>
<TD>318</TD>
<TD>303</TD></TR>
<TR>
<TD>5,500</TD>
<TD>307</TD>
<TD>322</TD></TR>
<TR>
<TD>5,800</TD>
<TD>298</TD>
<TD>329</TD></TR>
<TR>
<TD>6,000</TD>
<TD>286</TD>
<TD>327</TD></TR>
<TR>
<TR>
<TD colSpan=3>*Jim Grubbs SuperFlow engine dyno</TD></TR></T></TABLE>
Our 2-1/2-inch dual-cat cross-pipe from BBK Performance passed smog with flying colors while hardly affecting power at all. Remember cars will require a double-hump crossmember.</DIV>
<T>
<TR>
<TD align=middle colSpan=3>Non-50-state smog-legal rebuilt engine
<TR>
<TD colSpan=3>
<LI>650-cfm HP Holley carburetor
<LI>Performer RPM intake manifold
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>281</TD>
<TD>134</TD></TR>
<TR>
<TD>3,000</TD>
<TD>302</TD>
<TD>173</TD></TR>
<TR>
<TD>3,500</TD>
<TD>331</TD>
<TD>221</TD></TR>
<TR>
<TD>4,000</TD>
<TD>350</TD>
<TD>267</TD></TR>
<TR>
<TD>4,500</TD>
<TD>342</TD>
<TD>293</TD></TR>
<TR>
<TD>5,000</TD>
<TD>328</TD>
<TD>312</TD></TR>
<TR>
<TD>5,500</TD>
<TD>322</TD>
<TD>337</TD></TR>
<TR>
<TD>6,000</TD>
<TD>309</TD>
<TD>355
<TR>
<TR>
<T>
<TR>
<TR>
<TD colSpan=3>
<LI>Jetting 62 primary, 72 secondary
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>259</TD>
<TD>127</TD></TR>
<TR>
<TD>3,000</TD>
<TD>266</TD>
<TD>152</TD></TR>
<TR>
<TD>3,500</TD>
<TD>275</TD>
<TD>183</TD></TR>
<TR>
<TD>4,000</TD>
<TD>273</TD>
<TD>209</TD></TR>
<TR>
<TD>4,500</TD>
<TD>262</TD>
<TD>224</TD></TR>
<TR>
<TD>5,000</TD>
<TD>253</TD>
<TD>241</TD></TR>
<TR>
<TD>5,500</TD>
<TD>241</TD>
<TD>253</TD></TR>
<TR>
<TD>6,000</TD>
<TD>216</TD>
<TD>248</TD></TR>
<TR>
<TR>
<T>
<TR>
<TD align=middle colSpan=4>Parts Used And Tested</TD></TR>
<TR>
<TD>Description</TD>
<TD>PN</TD>
<TD>Source</TD>
<TD align=right>Price</TD></TR>
<TR>
<TD>*Accessory kit</TD>
<TD>554-9801</TD>
<TD>ARP</TD>
<TD align=right>$118</TD></TR>
<TR>
<TD>*Two-bolt main stud kit</TD>
<TD>154-5401</TD>
<TD>ARP</TD>
<TD align=right>36</TD></TR>
<TR>
<TD>Rod bolts</TD>
<TD>154-6402</TD>
<TD>ARP</TD>
<TD align=right>50</TD></TR>
<TR>
<TD>*Head bolts</TD>
<TD>154-3601</TD>
<TD>ARP</TD>
<TD align=right>38</TD></TR>
<TR>
<TD>*Carb studs</TD>
<TD>200-2401</TD>
<TD>ARP</TD>
<TD align=right>12</TD></TR>
<TR>
<TD>*Flywheel bolts</TD>
<TD>100-2801</TD>
<TD>ARP</TD>
<TD align=right>8</TD></TR>
<TR>
<TD>Cross-pipe with cats</TD>
<TD>1662</TD>
<TD>BBK Exhaust</TD>
<TD align=right>400</TD></TR>
<TR>
<TD>*Clutch housing assembly</TD>
<TD>CFT360025</TD>
<TD>Centerforce</TD>
<TD align=right>160</TD></TR>
<TR>
<TD>*Clutch disc</TD>
<TD>280490</TD>
<TD align=right>85</TD></TR>
<TR>
<TD>*Clutch release bearing</TD>
<TD>N1714</TD>
<TD align=right>35</TD></TR>
<TR>
<TD>Camshaft</TD>
<TD>35-514-8</TD>
<TD>Comp Cams</TD>
<TD align=right>246</TD></TR>
<TR>
<TD>Timing chain</TD>
<TD>2138</TD>
<TD>Comp Cams</TD>
<TD align=right>40</TD></TR>
<TR>
<TD>Pushrods</TD>
<TD>7621-16</TD>
<TD>Comp Cams</TD>
<TD align=right>109</TD></TR>
<TR>
<TD>Rockers</TD>
<TD>1442-16</TD>
<TD>Comp Cams</TD>
<TD align=right>150</TD></TR>
<TR>
<TD>Performer heads</TD>
<TD>60329</TD>
<TD>Edelbrock</TD>
<TD align=right>1,140</TD></TR>
<TR>
<TD>Performer intake w/EGR</TD>
<TD>3721</TD>
<TD>Edelbrock</TD>
<TD align=right>186</TD></TR>
<TR>
<TD>Four-barrel EGR plate</TD>
<TD>8053</TD>
<TD>Edelbrock</TD>
<TD align=right>60</TD></TR>
<TR>
<TD>*Water pump, std rotation</TD>
<TD>8840</TD>
<TD>Edelbrock</TD>
<TD align=right>148</TD></TR>
<TR>
<TD>*Water pump, rev rotation</TD>
<TD>8843</TD>
<TD>Edelbrock</TD>
<TR>
<TD>Sealed Power kit</TD>
<TD>Call Summit</TD>
<TD>Federal-Mogul</TD>
<TD align=right>270</TD></TR>
<TR>
<TD>After-cat exhaust</TD>
<TD>17213</TD>
<TD>Flowmaster</TD>
<TD align=right>320</TD></TR>
<TR>
<TD>1-5/8-inch shorty header</TD>
<TD>BIG-12107-FLT</TD>
<TD>FlowTech</TD>
<TD align=right>140</TD></TR>
<TR>
<TD>Clean and mag block</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TD align=right>80</TD></TR>
<TR>
<TD>Bore and torque-plate-hone</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TD align=right>225</TD></TR>
<TR>
<TD>Deck</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>Install cam bearings</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>Resize crank</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TD align=right>112</TD></TR>
<TR>
<TD>Resize rods</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TD align=right>124</TD></TR>
<TR>
<TD>Press piston pins</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TD align=right>48</TD></TR>
<TR>
<TD>*Rebuild service</TD>
<TD>N/A</TD>
<TD>Holley</TD>
<TD align=right>350</TD></TR>
<TR>
<TD>*Mechanical fuel pump</TD>
<TD>12-289-11</TD>
<TD>Holley</TD>
<TR>
<TD>*MSD -6AL box</TD>
<TD>6420</TD>
<TD>MSD</TD>
<TD align=right>230</TD></TR>
<TR>
<TD>*Blaster 2 coil</TD>
<TD>8202</TD>
<TD>MSD</TD>
<TR>
<TD>Wires, black</TD>
<TD>31323</TD>
<TD>MSD</TD>
<TD align=right>79</TD></TR>
<TR>
<TD>Adjustable timing control</TD>
<TD>8680</TD>
<TD>MSD</TD>
<TD align=right>128</TD></TR>
<TR>
<TD>*Pro-Clamp wire separators</TD>
<TD>8843</TD>
<TD>MSD</TD>
<TD align=right>17</TD></TR>
<TR>
<TD>Balance rotating assembly</TD>
<TD>N/A</TD>
<TD>WVEB</TD>
<TD align=right>190</TD></TR>
<TR>
<TD>Miscellaneous</TD>
<TD>silicone, oil, spark plugs, etc.</TD>
<TD></TD>
<TD align=right>213</TD></TR>
<TR>
<TD colSpan=3>*Total</TD>
<TD align=right>$4,500</TD></TR>
<TR>
<TD colSpan=4>All prices pulled from www.summitracing.com
*Factory parts are power adequate and can be reused. Price not included in engine total.</TD></TR></T></TABLE>
<T>
<TR>
<TR>
<TD colSpan=3>
<LI>FlowTech 1-5/8-inch short headers
<LI>BBK 2-1/2-inch dual-cat cross-pipe
<LI>Flowmaster 2-1/2-inch after-cat
<LI>Jetting 61 primary, 69 secondary
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>266</TD>
<TD>130</TD></TR>
<TR>
<TD>3,000</TD>
<TD>277</TD>
<TD>158</TD></TR>
<TR>
<TD>3,500</TD>
<TD>288</TD>
<TD>191</TD></TR>
<TR>
<TD>3,800</TD>
<TD>296</TD>
<TD>214</TD></TR>
<TR>
<TD>4,000</TD>
<TD>295</TD>
<TD>225</TD></TR>
<TR>
<TD>4,500</TD>
<TD>289</TD>
<TD>248</TD></TR>
<TR>
<TD>5,000</TD>
<TD>282</TD>
<TD>269</TD></TR>
<TR>
<TD>5,500</TD>
<TD>267</TD>
<TD>279</TD></TR>
<TR>
<TD>5,600</TD>
<TD>261</TD>
<TD>282</TD></TR>
<TR>
<TD>6,000</TD>
<TD>244</TD>
<TD>278</TD></TR>
<TR>
<TR>
<LI>Jetting was changed to optimize engine power with increased exhaust flow.</LI></TD></TR></T></TABLE><BR clear=all></DIV></DIV>
<T>
<TR>
<TR>
<TD colSpan=3>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>246</TD>
<TD>118</TD></TR>
<TR>
<TD>3,000</TD>
<TD>254</TD>
<TD>146</TD></TR>
<TR>
<TD>3,200</TD>
<TD>256</TD>
<TD>158</TD></TR>
<TR>
<TD>3,500</TD>
<TD>255</TD>
<TD>171</TD></TR>
<TR>
<TD>4,000</TD>
<TD>240</TD>
<TD>183</TD></TR>
<TR>
<TD>4,400</TD>
<TD>223</TD>
<TD>188
<TR>
<TD>4,500</TD>
<TD>219</TD>
<TD>188</TD></TR>
<TR>
<TD>5,000</TD>
<TD>193</TD>
<TD>184</TD></TR>
<TR>
<TD>5,500</TD>
<TD>160</TD>
<TD>168</TD></TR>
<TR>
<TD>6,000</TD>
<TD>N/A</TD>
<TD>N/A</TD></TR>
<TR>
<TR>
<T>
<TR>
<TR>
<TD colSpan=3>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>294</TD>
<TD>140</TD></TR>
<TR>
<TD>3,000</TD>
<TD>306</TD>
<TD>175</TD></TR>
<TR>
<TD>3,500</TD>
<TD>313</TD>
<TD>209</TD></TR>
<TR>
<TD>3,600</TD>
<TD>337</TD>
<TD>232
<TR>
<TD>4,000</TD>
<TD>336</TD>
<TD>256</TD></TR>
<TR>
<TD>4,500</TD>
<TD>330</TD>
<TD>283</TD></TR>
<TR>
<TD>5,000</TD>
<TD>318</TD>
<TD>303</TD></TR>
<TR>
<TD>5,500</TD>
<TD>307</TD>
<TD>322</TD></TR>
<TR>
<TD>5,800</TD>
<TD>298</TD>
<TD>329</TD></TR>
<TR>
<TD>6,000</TD>
<TD>286</TD>
<TD>327</TD></TR>
<TR>
<TR>
<T>
<TR>
<TR>
<TD colSpan=3>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>281</TD>
<TD>134</TD></TR>
<TR>
<TD>3,000</TD>
<TD>302</TD>
<TD>173</TD></TR>
<TR>
<TD>3,500</TD>
<TD>331</TD>
<TD>221</TD></TR>
<TR>
<TD>4,000</TD>
<TD>350</TD>
<TD>267</TD></TR>
<TR>
<TD>4,500</TD>
<TD>342</TD>
<TD>293</TD></TR>
<TR>
<TD>5,000</TD>
<TD>328</TD>
<TD>312</TD></TR>
<TR>
<TD>5,500</TD>
<TD>322</TD>
<TD>337</TD></TR>
<TR>
<TD>6,000</TD>
<TD>309</TD>
<TD>355
<TR>
<TR>
<T>
<TR>
<TR>
<TD colSpan=3>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>259</TD>
<TD>127</TD></TR>
<TR>
<TD>3,000</TD>
<TD>266</TD>
<TD>152</TD></TR>
<TR>
<TD>3,500</TD>
<TD>275</TD>
<TD>183</TD></TR>
<TR>
<TD>4,000</TD>
<TD>273</TD>
<TD>209</TD></TR>
<TR>
<TD>4,500</TD>
<TD>262</TD>
<TD>224</TD></TR>
<TR>
<TD>5,000</TD>
<TD>253</TD>
<TD>241</TD></TR>
<TR>
<TD>5,500</TD>
<TD>241</TD>
<TD>253</TD></TR>
<TR>
<TD>6,000</TD>
<TD>216</TD>
<TD>248</TD></TR>
<TR>
<TR>
<T>
<TR>
<TR>
<TD>PN</TD>
<TD>Source</TD>
<TR>
<TD>554-9801</TD>
<TD>ARP</TD>
<TR>
<TD>154-5401</TD>
<TD>ARP</TD>
<TR>
<TD>Rod bolts</TD>
<TD>154-6402</TD>
<TD>ARP</TD>
<TR>
<TD>154-3601</TD>
<TD>ARP</TD>
<TR>
<TD>200-2401</TD>
<TD>ARP</TD>
<TR>
<TD>100-2801</TD>
<TD>ARP</TD>
<TR>
<TD>1662</TD>
<TR>
<TD>CFT360025</TD>
<TR>
<TD>280490</TD>
<TR>
<TD>N1714</TD>
<TR>
<TD>Camshaft</TD>
<TD>35-514-8</TD>
<TD>Comp Cams</TD>
<TR>
<TD>2138</TD>
<TD>Comp Cams</TD>
<TR>
<TD>Pushrods</TD>
<TD>7621-16</TD>
<TD>Comp Cams</TD>
<TR>
<TD>Rockers</TD>
<TD>1442-16</TD>
<TD>Comp Cams</TD>
<TR>
<TD>60329</TD>
<TD>Edelbrock</TD>
<TR>
<TD>3721</TD>
<TD>Edelbrock</TD>
<TR>
<TD>8053</TD>
<TD>Edelbrock</TD>
<TR>
<TD>8840</TD>
<TD>Edelbrock</TD>
<TR>
<TD>8843</TD>
<TD>Edelbrock</TD>
<TR>
<TR>
<TD>17213</TD>
<TD>Flowmaster</TD>
<TR>
<TD>FlowTech</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>Deck</TD>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>JGM</TD>
<TR>
<TD>N/A</TD>
<TD>Holley</TD>
<TR>
<TD>12-289-11</TD>
<TD>Holley</TD>
<TR>
<TD>6420</TD>
<TD>MSD</TD>
<TR>
<TD>8202</TD>
<TD>MSD</TD>
<TR>
<TD>31323</TD>
<TD>MSD</TD>
<TR>
<TD>8680</TD>
<TD>MSD</TD>
<TR>
<TD>8843</TD>
<TD>MSD</TD>
<TR>
<TD>N/A</TD>
<TD>WVEB</TD>
<TR>
<TD></TD>
<TR>
<TR>
<T>
<TR>
<TR>
<TD colSpan=3>
<TR>
<TD>RPM</TD>
<TD>RWTQ</TD>
<TD>RWHP</TD></TR>
<TR>
<TD>2,500</TD>
<TD>266</TD>
<TD>130</TD></TR>
<TR>
<TD>3,000</TD>
<TD>277</TD>
<TD>158</TD></TR>
<TR>
<TD>3,500</TD>
<TD>288</TD>
<TD>191</TD></TR>
<TR>
<TD>3,800</TD>
<TD>296</TD>
<TD>214</TD></TR>
<TR>
<TD>4,000</TD>
<TD>295</TD>
<TD>225</TD></TR>
<TR>
<TD>4,500</TD>
<TD>289</TD>
<TD>248</TD></TR>
<TR>
<TD>5,000</TD>
<TD>282</TD>
<TD>269</TD></TR>
<TR>
<TD>5,500</TD>
<TD>267</TD>
<TD>279</TD></TR>
<TR>
<TD>5,600</TD>
<TD>261</TD>
<TD>282</TD></TR>
<TR>
<TD>6,000</TD>
<TD>244</TD>
<TD>278</TD></TR>
<TR>
<TR>
#9
A good tip when doing thes bolt ons to the stock 5.0 is that the pistons are junk and since they are not the 5.0 H.O they will not clear anything bigger then a stock H.O cam. So if you are keeping the stock pistons, you are wasting your time. That is why I posted a more expensive build because the 5.0 H.O is the motor to start out with unless you build yours to fit the the componets of the 5.0.
The cool thing all the hard work has been done and you can pick and choose parts since you might already have some.
Me personally, I like to just swap the Mustang cobra setup since it is Verrry cheap used parts and they fit with awesome performance. Most cobra parts are cheap because they are sold on ebay after guys get bigger and better parts.
