Engine & Internal Chat about beefing up your engine's insides here...
Sponsored by:
Sponsored by:
vibration
Old Oct 21, 2005 | 12:44 AM
panther92's Avatar
I have a issue with my 92 Marquis. As soon as I start to hit the gas i get this weird vibration, it seems like something is rubbing on the drive shaft. But when I turn left everything is fine until I straighten the wheel, then it comes back.
Could this be a brake problem or a suspension issue(ball joints,tie-rod)
Please help.
Old Oct 24, 2005 | 03:12 PM
Patrick's Avatar
Administrator
a braking issue would come and go as you depress and let off of the brake pedal. try jacking up the front end and shaking it down, checking for extra play in the front tires...
Old Nov 10, 2005 | 03:44 PM
Lenny's Avatar
do you get the vibration in the steering wheel or at your feet? If you get it in the wheel sounds like a wheel bearing. If you get it at your feet under acceleration,sounds like a timing/ignition issue.
gpemb
Dec 4, 2006 12:11 PM
chrisbradbury
Sep 1, 2006 01:51 AM
chrisbradbury
Sep 1, 2006 01:32 AM
jr105
May 17, 2006 10:07 AM
John Poole
Mar 28, 2006 11:50 PM
