Hello, I have a 1980 Grand Marquis, and i have a problem. Im not getting any spark . I have replaced many parts, and my mechanic is stumped like me. Any advice is helpful. Thanks Lobato60
Have you tried replacing the igintion module?
I have replaced it, i could have gotten a bad one, could it be the computer? My mechanic gave me the numbers and i cant find one.
I'd check the wires and wiring going to the igintion module very closely, see if your getting the right signals, and troubleshoot from there. If all is good then its possible you did get a bad one, but T/S the signal first.....
wow check to see if your getting power where it needs to be you should be getting a code from a scanner . might be ignition switch. |
