1994 Mercury Grand Marquis LS recommended Tire Pressure???
Old 07-27-2009, 07:31 AM
yup... both of my boats are Canada Vins aye!
  #12
Old 02-16-2019, 02:35 PM
Default Correct Tire Pressures
Originally Posted by BCmerc
Kind of a simple, but very important question...lol I just bought a 94 Grand Marquis LS 4.6L There was no manual and no tire pressure decal where it normally is on the door/doorjam. Tires are rated for 35 psi max, but thats just the max tire pressure for the rubber. What I need to know is if anyone has the actual manufacture recommended tire pressure for a 1994 grand marquis. As far as I know most Grand Marquis are 31 psi front and 35 psi rear, but I just want to confirm that its the same for the 1994. Any help would be appreciated. Thanks.
GoodYear Assurance ComforTread Touring Tires. 215 x 70R x 15 -- on '93 Lincoln Wheels -- Made in Italy. Mercury Hub Caps.
Tire Pressures on all models of '91 thru '95 Grand Marquis with 15" wheels --
Tire pressures should be checked BEFORE the car is driven -- in the shade, if possible.
The Factory-specified tire pressures for the 1992 thru 1995 Grand Marquis with 215x70Rx15 radial tires:
Front = 32 p.s.i (cold)
Rear = 35 p.s.i. (cold)
The Tire Inflation Decal is attached to the body, at the Passenger's Side Rear Door.
Recommended Load/Speed Rating = 98 T (118 mph). DO NOT use a pencil-type tire gauge -- get a DIGITAL gauge -- I use a CRAFTSMAN digital gauge -- it's very accurate to .5 lb. (one-half pound) psi.
  #13
Old 12-04-2020, 06:03 AM
Alex Vanbenschoten's Avatar
So idk if anyone has thought of this but how about making the car into a sleeper😅
  #14
Old 12-04-2020, 12:48 PM
Default Sleeping Beauty
Sleeper !?? I don't know about that -- most people want to make rockets out of these 2-ton whalemobiles for as-yet-unfathomable reasons.
The 95 MERC was built for long-distance, high-speed touring throughout the deserts and mountains of the American Southwest, with little thought given to it being a "sleeper" -- preferring instead to keep things on the down-low.
What modifications do you suggest for making a Grand Marquis into the coveted "sleeper" ??
Sleeping Beauty, Rolling Thunder
  #15
Old 12-04-2020, 01:26 PM
well I was thinking on throwing a super charger on it since mine is the 2 valve 4.6 so imma just make it into a little sleeper not ridiculous
  #16
Old 12-04-2020, 01:27 PM
apple2005
10-11-2018 11:34 AM
T_Wayne
09-21-2011 01:12 PM
87GMARK5.0
03-25-2011 01:32 PM
crazycraig68
09-23-2009 09:47 AM
SEFH
11-20-2006 09:55 AM
Quick Reply: 1994 Mercury Grand Marquis LS recommended Tire Pressure???
