-   -   2000 Mercury Mystique (https://www.mercuryforum.com/forum/general-tech-help-12/2000-mercury-mystique-242/)
dreamgirl_i Jul 12, 2005 11:44 AM
I need help. My ac/heater is only blowing air out when I have it set on the high setting. I have been told it could be the motor blower resistor and/or the motor blower. Any ideas?
Also, does any one know where those are located? Does anyone have an ac diagram to show me?
Any help is appreciated,Thanks! [img]smileys/smiley1.gif[/img]
MercAdvisor Jul 12, 2005 03:25 PM
Id say im 99% sure you have a bad resistor. Its behind the glove box near the blower motor. Id say check with your dealer some of those vehicles had a recall on the resistor im not sure which years it was though .[img]smileys/smiley2.gif[/img]
dreamgirl_i Jul 12, 2005 03:56 PM
i have checked with the dealer but no recalls on my vehicle.
i read apost on the ford forum where this guy seemed to have the same problem. he saiditwasn't the resistor, itwas dirty/melted contacts in the plug. what is that? and how do i fix it without taking it to the dealer and it cosing me a fortune?
if it is the resistor, how do i fix that? i won't be the one fixing it, my boyfriend will be doing it. but any information on how to do it would be real helpful.
Thanks!
MercAdvisor Jul 12, 2005 08:55 PM
I have seen the plug to the motor or resistor melt also . The parts are actually realtivly cheap it wouldnt hurt to put on both. IF you got to a ford or linc merc dealer and explain what your looking for im sure the parts advisor you get should be able to help you relativly easily.
dreamgirl_i Jul 13, 2005 10:49 AM
Thank you so much, you have been extremely helpful. [img]smileys/smiley20.gif[/img]
Lenny Jul 16, 2005 10:56 AM
check out http://fordcontour.org
conan312 Nov 10, 2005 11:49 PM
you need a low speed fan switch.
Lenny Nov 11, 2005 10:25 AM
There is also a fusible link under the drivers cowl panel(panel outside under windshield wiper) that has 2 red wires going to 1. I know that 98/99 had problems with these after the recall on the blower motor resistor pack was replaced.
