2001 grand Marquis fuel pump
Old Oct 4, 2019 | 10:55 AM
thecomputerguy81's Avatar
Default 2001 grand Marquis fuel pump
hey what's up all.. I'm needing a bit of help with a fuel pump issue. on a 2001 grand marquis.. I replaced the fuel pump already... but I'm getting less than 1 volt at the intertia switch.. and no power to the fuel pump. does this car have a relay. and fuse? and is there a way I can just bypass the inertia switch and run 12 volt to the fuel pump itself?
any help would be greatly apreciated
Old Oct 13, 2019 | 06:25 AM
raski's Avatar
If you are getting the same reading on both ends of the switch, it is not the cause of your issue.The relays are in a box, on the driver's side top of inner fender near the master cylinder. The fuel pump relay is the middle one i believe. You can swap it with the a/c relay and see if it works.
chuck gibson
Mar 7, 2022 01:52 PM
Johnw
May 16, 2016 06:34 AM
sllim0725
Apr 24, 2010 06:31 AM
nrlanni
Feb 20, 2009 08:36 AM
