-   -   97 Sable ignition (https://www.mercuryforum.com/forum/general-tech-help-12/97-sable-ignitin-273/)
sinned Aug 13, 2005 11:17 AM
I'm having trouble with the steering column ignition switch. To crank the car I have to turn it to accessory and forward to crank it. Most of the time after I turn it to Acc. I have to turn the steering wheel back and forth until it finds the right position before it will crank. Is this the ignition switch bad or is it possible the key is bad?My keydoesn't look like the original key for the car. Thanks
