I have a water leak, but can't figure out where it is comming
from. The water drips from the inside roof, front center digital readout. It also drips from between the windshield and the roof/ceiling, over both the driver and passenger front seats. Is the leak comming from the windshield, or the sunroof? Thanks, Eric Dixon South Carolina |
have you ever had either replaced?
I just got the truck from my father. The sunroof looks original, but I'm not sure about the windshield. The water mainly drips from the center of the digital readout on the ceiling. From theopening just below the numbers, where the screen meets the dark grey plastic.
PULL HEADLINER DOWN ON LEFT AND RIGHT SIDES WILL PROBABLY FIN DRAIN HOSES TO SUNROOF BROKEN OR OFF IM A SHP FOREMAN FOR FORD AND HAVE 23YRS EXP HOPE THIS HELPS
I'll try that today. Thank you for your help!
| All times are GMT -5. The time now is 10:36 AM. |
