I'm having a problem on my 98 Sable with the headlights and dash panel lights flickering. I have recently replaced the alternator (it was totally shot),thinking that was the cause, but it's still doing it. Not a real big problem (yet) but it's kind of annoying when driving down the highway at night. Any ideas or suggestions would be greatly appreciated. |
do you have an aftermarket stereo or anything?
No, everything is OEM. Someone else suggested checking the ground off the battery, so I hope to be doing that soon. Hope that's the fix. |
CHECK HEADLAMP SWITCH TO BE SUR THE CONNECTOR AND WIRING IS NOT MELTING WAS A COMMON PROBLEM CAUSING LIGHTS TO FLICKER LET ME KNOW GOOD LUCK
| All times are GMT -5. The time now is 06:54 AM. |
