-   -   99 Cougar 4 Cyl serpentine belt removal (https://www.mercuryforum.com/forum/general-tech-help-12/99-cougar-4-cyl-serpentine-belt-removal-4208/)
trailhand Apr 7, 2010 09:22 PM
Trying to locate the tensioner on my 4 cyl motor to remove the serpentine belt. I think I know which one it is but its not an easy one to reach and there's not enough room to put a socket on it. Is it the size 13 located just under the alternator? Tried pulling it in with a box end wrench but maybe I didn't put enough gorilla into it.:mad:
orten999 Apr 24, 2010 06:47 AM
Thanks for share this information, I really didn't know about that, will get advantage from this,Thanks for share this.
Term Papers
Samohajo May 19, 2010 01:08 AM
The serpentine belt goes around an idler gear. This idler has rides on a base plate
that can be rotated to tighten or loosen the belt. You must be shure that you have the right belt before you adjust the tension. If you overtighten the belts, you will cause excess heat in the bearings or water pump or air pump, etc. Be very sure that no belt is stretched too tightly or too loosely.
