Battery dying
My 2 year old battery on my 96 MGM loses its charge if I don't drive it every other day. In these days of stay at home I haven't been driving it as much. Is this normal? Is there a way to check the battery to see if something is on that I don't know about? I know how to do it on a pre-computer car but not on this. Thanks in advance. Rich W the battery light does not come on when driving it. Voltage when idling is 14.7
The "quick & dirty" way to check for current loss -- Disconnect the fully-charged battery. Wait for 2 days. If the battery loses it's charge, it's junk.
Of course, the correct way to check a standard, lead-acid battery is with a Hydrometer -- like the battery manufacturers recommend. Most hydrometers are a P.I.A. to operate, but the E-Z-Red Hydrometer (Amazon) is super-easy to use and to read. A common mistake is to OVER-FILL the battery -- causing random corrosion all over the battery area. Fill the battery to the BOTTOM of the fill hole, using distilled water ONLY. Those Red&Green Felt Rings on the battery terminals help to keep them corrosion-free. |
| All times are GMT -5. The time now is 07:45 AM. |
